Home > Technical (L322) > Transfer box motor?
Page 5 of 7 <1234567>
povh
Slovenia 2005 Range Rover Autobiography Td6 Giverny Green
Nice to hear that same technique worked for you too guys.
Just for info, mine is still working 100% ( more than 6 months now).
Post #391324 12th Jun 2016 12:12am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Just been reading this with interest, good info to remember. Just a thought, has anyone had experience of a product called Superslide, its a graphite based lube used by Piano techs. I recall reading it being used to repair pots on vintage radios. It is painted on and dries, the more coats the less resistance,...
http://www.heckscher.co.uk/superslide-blac...ion-parts/ 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #391462 13th Jun 2016 6:54am
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Thanks for the info on this issue. I pulled the potentiometer out yesterday, split it and tweaked the pins/re-melted the soldered joints and rejoined the two halves. High low now working perfectly.
This is definitely a four spanner job though!
Post #392219 19th Jun 2016 9:22am
Jimmy C
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
Dont fancy doing another do you? Whistle
Post #392779 23rd Jun 2016 2:58pm
mr_spock
I'd be happy to. Frankly it's pretty simple once you get your head round it!
Post #392781 23rd Jun 2016 3:09pm
ndg
Likewise,
If you bring just the potentiometer (2 spanner job to get it out) it'd take about 40mins.
Post #392782 23rd Jun 2016 3:12pm
verydisco
Same here for the Frenchies in need. Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #392785 23rd Jun 2016 3:15pm
Jimmy C
ndg wrote:
Likewise,
I'll take you up on that offer, im near Leicester so not to far away, will be 2/3 weeks though as im on holiday after today Very Happy
Post #392786 23rd Jun 2016 3:18pm
ndg
Drop me a message when you've back and I'm sure we can sort something out Thumbs Up
No guarantees etc!
Post #392787 23rd Jun 2016 3:29pm
wayneg
This is another product I think would make a good repair, its used amongst other things to paint cavities in electric guitars to stop Hum. Its black carbon based. http://www.ebay.com.au/itm/Electric-Wire-D...Sw8-tWW-vO 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #392846 24th Jun 2016 4:14am
miggit
Got to ask, as LR are no help... is this not the same thing?
http://www.ebay.co.uk/itm/APDTY-711231-Tra...1735953807
Only I can't for one minute think that it's a part that LR have commissioned specially for the ffrr.. it will be another off the shelf part re boxed with a LR sticker and the decimal point moved in the price Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #412552 7th Nov 2016 5:18pm
RRPhil
Certainly looks similar, but the NV225 shift motor potentiometer has a hexagonal recess on its underside to locate and align it
Phil
Post #412621 8th Nov 2016 1:22am
miggit
Sad Keep searching........
Unless there is a nice chap in the US who might be able to cop hold of a S/H one and do a comparison... Yesterday I couldn't spell Engineer... Today I are one!
Post #412622 8th Nov 2016 1:32am
wayneg
This vidio shows the guts of the GM motor and Potentiometer swap. I wonder if the innards of the potentiometer could be swapped from the GM to RR one?
https://www.youtube.com/watch?v=loqBDJnipDc 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #412647 8th Nov 2016 1:33pm
miggit
I'm wondering if it wont just fit.. it has the notch, but not the hex bit... but the hex bit looks to be raised so maybe the GM one will just fit Rolling Eyes
I don't think that anyone in the UK is going to answer the question.. as big engined GM 4x4's are like hens teeth over here... at least they sold them as the Holden down under. Best case is someone in the US has a crack at it.. those pots are only $39 new Shocked I bet that a S/H could be had for way less... or better still a duff unit from a garage just to see if it will fit Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #412648 8th Nov 2016 1:44pm
