Home > Technical (L322) > FBH stopped working |
onyx Member Since: 08 Aug 2012 Location: stoke on trent Posts: 28 |
Hi,first post on here but been with you since I purchased my 55reg ( facelift) in July.Love the beast and since I've had it I have fitted the digital tv upgrade and the iPhone module upgrade, after reading up on this Forum.Problem is, I've just fitted a lovely new leather steering wheel from Powerful but now the FBH doesn't work ?.you have to disconnect the battery to do this and the job is easy but the heater won't switch on using either the (2) remotes or the touchscreen timer.It was freezing last night so no problem with temperature ?Any ideas.Its a TD6 |
6th Dec 2012 5:14pm |
Yes, worked perfectly with either remote or the timer ? |
6th Dec 2012 5:20pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Just a thought... If the battery voltage was below a threshold, it might not switch on the FBH. I take it car starts first crank? Have you checked the relevant fuse? Maybe disconnect battery again. Previously..
6th Dec 2012 5:25pm |
2 month old Bosch battery,starts straight away, using a remote heater starts and light comes on inside but cuts out after 15secs ? |
6th Dec 2012 5:29pm |
Ah, thats different... It Does switch on, it just doesn't stay on.. Previously..
6th Dec 2012 6:13pm |
Yes, worked perfectly in the morning when I used the remote to start it at work, went bed , got up and fitted steering wheel and then wouldn't work next morning ?, puzzled !! |
6th Dec 2012 6:17pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8659 |
Have a good search on here there is a lot on the fbh, they seem to be a bit temperamental.
6th Dec 2012 6:30pm |
Sounds like the glow plug might have gone. If it doesn't ignite within about 15 seconds it shuts off. That's what mine was doing. Easy fix once you get to it. Access is the biggest problem.
6th Dec 2012 6:31pm |
Yes, read up all the posts I could find before I purchased 2 T91s and programmed them to the car by removing rear unit plug, as I said, was working perfectly before fitting/disconnecting battery, now, by the wheel arch you here the low whine for 15/20 secs then nothing. |
6th Dec 2012 6:37pm |
Yep, that sounds broken. Could be the glow plug, do you hear the ticking from the rear of the car, indicating the fuel pump is running, as if not it may point to a faulty pump. There is nothing that can't be fixed with a hammer😜😜
6th Dec 2012 6:55pm |
No, use to here ticking at rear but nothing now |
6th Dec 2012 6:58pm |
Update,being trying for a few days but still cut out after about 15secs!!,today whilst it was still below freezing (so no temperature issue) I disconnected battery for a minute or so and then tried again but still nothing different.Tried it once more and hey presto kicked in as it always had ???.No idea why ,so if you have a problem, keep trying !.Just hope it works tonight when I go to work |
11th Dec 2012 4:14pm |
Update,switched remote on,came out after 20mins,yes you guessed it,freezing cold.Stumped now.Anyone any ideas ?. |
12th Dec 2012 12:40am |
That sounds like what mine was doing, check its going through the correct pre ignition sequence, fuel pump ticking etc.
12th Dec 2012 5:40pm |
