Home > Technical (L322) > FBH stopped working
onyx
England 2005 Range Rover Vogue Td6 Java Black
FBH stopped working
Hi,first post on here but been with you since I purchased my 55reg ( facelift) in July.Love the beast and since I've had it I have fitted the digital tv upgrade and the iPhone module upgrade, after reading up on this Forum.Problem is, I've just fitted a lovely new leather steering wheel from Powerful but now the FBH doesn't work ?.you have to disconnect the battery to do this and the job is easy but the heater won't switch on using either the (2) remotes or the touchscreen timer.It was freezing last night so no problem with temperature ?Any ideas.Its a TD6
Post #155831 6th Dec 2012 5:14pm
Welcome.. Thumbs Up
Are you sure it was working before you changed the steering wheel? Previously..
Post #155833 6th Dec 2012 5:18pm
onyx
Yes, worked perfectly with either remote or the timer ?
Post #155834 6th Dec 2012 5:20pm
Just a thought... If the battery voltage was below a threshold, it might not switch on the FBH. I take it car starts first crank? Have you checked the relevant fuse? Maybe disconnect battery again. Previously..
Post #155837 6th Dec 2012 5:25pm
onyx
2 month old Bosch battery,starts straight away, using a remote heater starts and light comes on inside but cuts out after 15secs ?
Post #155840 6th Dec 2012 5:29pm
Ah, thats different... It Does switch on, it just doesn't stay on.. Previously..
Post #155845 6th Dec 2012 6:13pm
onyx
Yes, worked perfectly in the morning when I used the remote to start it at work, went bed , got up and fitted steering wheel and then wouldn't work next morning ?, puzzled !!
Post #155846 6th Dec 2012 6:17pm
Have a good search on here there is a lot on the fbh, they seem to be a bit temperamental.
Basically you should hear.
1. Slow fuel pump click to start with as the heater primes
2. Faster fuel pump click as the heater ignites
3. Burner fan kicks in.
4. feel hot flue gasses under car by front passenger wheel.
5. Signal sent to divert hot water to the heater matrix.
Dont confuse the ventillation fans with the fbh when listening, they will run at the start.
You are listening around the front passenger wheel arch area.
See where yours gets up to..... There is nothing that can't be fixed with a hammer😜😜
Post #155847 6th Dec 2012 6:30pm
mzplcg
Sounds like the glow plug might have gone. If it doesn't ignite within about 15 seconds it shuts off. That's what mine was doing. Easy fix once you get to it. Access is the biggest problem.
Does the exhaust get hot? (FBH exhaust, not the car) - I suspect it doesn't, in which case it isn't actually igniting the burner. The vast majority of ignition failures are caused by a duff glow plug.
Sequence to listen for is ticking of fuel pump, fans coming on and then a lowish whistle sound. If you don't get that sequence it should tell you which bit is not working from the missing item.
Good luck.
Post #155848 6th Dec 2012 6:31pm
onyx
Yes, read up all the posts I could find before I purchased 2 T91s and programmed them to the car by removing rear unit plug, as I said, was working perfectly before fitting/disconnecting battery, now, by the wheel arch you here the low whine for 15/20 secs then nothing.
Post #155851 6th Dec 2012 6:37pm
Yep, that sounds broken. Could be the glow plug, do you hear the ticking from the rear of the car, indicating the fuel pump is running, as if not it may point to a faulty pump. There is nothing that can't be fixed with a hammer😜😜
Post #155859 6th Dec 2012 6:55pm
onyx
No, use to here ticking at rear but nothing now
Post #155861 6th Dec 2012 6:58pm
onyx
Update,being trying for a few days but still cut out after about 15secs!!,today whilst it was still below freezing (so no temperature issue) I disconnected battery for a minute or so and then tried again but still nothing different.Tried it once more and hey presto kicked in as it always had ???.No idea why ,so if you have a problem, keep trying !.Just hope it works tonight when I go to work Bow down
Post #156729 11th Dec 2012 4:14pm
onyx
Update,switched remote on,came out after 20mins,yes you guessed it,freezing cold.Stumped now.Anyone any ideas ?. Big Cry
Post #156834 12th Dec 2012 12:40am
That sounds like what mine was doing, check its going through the correct pre ignition sequence, fuel pump ticking etc.
failing that it could be one of several things, there is quite a lot of info on all of them and im no expert, however, there are several things which seem to go wrong,
Glow plug, ECU, blocked FBH water pump and the water control valve.
If it was working fine the other day it may be worth checking all of the connections to the unit, to the water valve etc, it can be accessed by removing the wheel arch liner on the passenger side, which is do-able with the wheel on in off road height., whilst it is accessable the pump can be checked by clamping off the hoses and disconnecting them from the unit.
If the ECU on the unit has gone kaput then there is someone (seen it in a thread on here) who will recon the edu. As far as the water control valve goes, this diverts the water to the heater matrix and is a PITA to get to as it is behind the engine on the outside of the cabin bulkhead.
When i had mine fixed under warranty last week they replaced the entire unit, though i suspect that the ecu was the part which had failed, it had similar symptoms to yours, seemed to fire up but cold car 20 mins later. If you are reasonable with spanners then the FBH can be removed and cleaned, new glow plug fitted etc off the car, i have got as far as checking the pump and wiring, but it looked fairly simple if a little fiddly in places to remove.
These are pretty much all of the parts involved in making it work..... There is nothing that can't be fixed with a hammer😜😜
Post #157003 12th Dec 2012 5:40pm
