![]() | Home > Maintenance & Mods (L322) > Condensation in rear light..... |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
i cleaned the joint between the lense on mine around 3 years ago and flooded/sealed it with superglue and still no problems |
I used Hoover on max power and it sucked out all moisture. I too drilled a small hole underneath light unseen and have had no issues since. Present :2008 TDV8 HSE
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 ![]() ![]() ![]() |
I had a similar problem on an indicator lens, dried it out first and then tried Capt. Tolleys - it didn't work.
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
I drilled that hole too.funny thing is that it worked on the rear/right but the rear/left is constantly fogged up and has a little bit of mould growing in it along with the front right indicator.Will have to go at it again me thinks.
