Home > Maintenance & Mods (L322) > Condensation in rear light..... |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
i cleaned the joint between the lense on mine around 3 years ago and flooded/sealed it with superglue and still no problems |
2nd Dec 2012 10:35pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I used Hoover on max power and it sucked out all moisture. I too drilled a small hole underneath light unseen and have had no issues since. Present :2008 TDV8 HSE
3rd Dec 2012 12:07am |
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 |
I had a similar problem on an indicator lens, dried it out first and then tried Capt. Tolleys - it didn't work.
3rd Dec 2012 12:09am |
3rd Dec 2012 12:30am |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
I drilled that hole too.funny thing is that it worked on the rear/right but the rear/left is constantly fogged up and has a little bit of mould growing in it along with the front right indicator.Will have to go at it again me thinks.
3rd Dec 2012 10:04am |
