Home > In Car Electronics (L322) > Thanks Baris
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Thanks Baris
After buying my 2004 vogue knowing its mk3 satnav unit was dead I was lucky to find baris!
He sent me a updated mk4 unit with 2012 disk and WOW.
So much more up to date looks and use!
I can highly recommend this guy for sat nav upgrades!
Also nice to have a splash screen again!!
Thanks Baris, I'm sooo happy with it!!
Post #154847 2nd Dec 2012 8:27am
Baris
No problem mate Thumbs Up
The mk4 doesn't just effect the navigation, but the speed of the whole system as well.
Post #157364 14th Dec 2012 10:39am
SATVC
Thanks baris
The only other thing I want to add at some point is an iPod/iPhone connection to the system.
What would you recommend for best result and can you supply the required items?
Post #157519 14th Dec 2012 8:18pm
Baris
You have a few options, depending on how much you want to spend.
The best of the best, is the intravee, as it will display all tracks on screen, and you can control everything from the car. This is about £250 for a used one.
I make my own connections, using the AUX input. A simple 3.5mm jack cable is £20. Your bm54 would most likely need a firmware upgrade, to recognize the AUX mode. You then have other options, like a ipod cable, which will also charge the device, and also my bluetooth music streaming.
All these options, accept the intravee, require modification on the bm54 unit.
Post #165664 18th Jan 2013 12:25pm
SATVC
[mod edit, please dont use the quote button when replying to a post ]
I'm defo gonna get a bm54 upgrade from you soon! But waiting on time to remove the unit!
Looking at iPod lead and aux out for extra amp at some time!
Ill be in touch soon I have your repair form already for you!!
Post #165673 18th Jan 2013 1:20pm
