Home > Off Topic - Other Cars > Jaguar XK-R Sat NAV issues?
Hi Guys I hope one of you electronic genius's can help me.
I just picked up a very nice 2007(57) Jaguar XK-R (like new) with standard factory Jaguar Sat Nav.
Problem is the cursor has no idea where it is and does not appears to be receiving the GPS signal.
Everything else works perfectly on the unit.
Any ideas?
Gaz
Post #154564 30th Nov 2012 4:11pm
Arenaitch
Simple check - is the compass pointing north (or as near north as you know it to be) and keep pointing there when the car does?
If it is, it suggests the signal is being received and the unit is at least partially working (receives signal, processes it, changes screen accordingly), if it isn't or doesn't move then it doesn't actually prove much, since it could be either a signal issue or a unit issue. 2012 FFRR Westminster Orkney / Ivory and absolutely no pimp-glass!
Post #154571 30th Nov 2012 4:33pm
You can orient the Map true North or Direction but direction is obviously not the same direction as the car is going!
Post #154579 30th Nov 2012 4:59pm
Martin
Site Admin
Antenna or wiring between antenna and nav module at fault.
Post #154584 30th Nov 2012 5:09pm
There should be a settings mode on it to allow you to see the satellite signal strength I would have thought. Previously..
Post #154587 30th Nov 2012 5:16pm
Will have another fiddle tomorrow - very frustrating had a few Jags with this Nav and never seen this....
Interestingly there is a setting to allow you to re-set the cursor position to anywhere you choose (calibration) which I though odd as the GPS should do that surely?
Post #154588 30th Nov 2012 5:20pm
Probably similar to the setting the FF uses to re calibrate ====================================
Post #154589 30th Nov 2012 5:22pm
Not being a SAT NAV expert Mick how do you get into that on a FF?
Post #154590 30th Nov 2012 5:24pm
Its been that long since i have done it Gaz i cannot remember off the top of my head … but its done via the settings menu …. ====================================
Post #154592 30th Nov 2012 5:28pm
Maybe this guy might be able to help you as well Gaz ….
http://www.designxkr.co.uk/index.html ====================================
Post #154593 30th Nov 2012 5:32pm
OK I think I have fixed it by re-cailbrating the system by moving the map until the cursor was sitting in exactly the current location and oriented in the exact right direction. I saved the setting and drove half way round the block and it worked but I thought this may be dead reckonning so I set my home as destination and it all worked tickertee boo.
This is the beast in question quite a stunning car:
Post #154600 30th Nov 2012 5:50pm
Thats a nice looking XK-R. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #154601 30th Nov 2012 5:53pm
Arenaitch
Traded my XK for the Westie. Must say I do think that the Jag touch screen / sat nav /menu / facilities / controls leaves the RR version in the shade.
Silly question - the sat nav drive in the boot is working? 2012 FFRR Westminster Orkney / Ivory and absolutely no pimp-glass!
Post #154616 30th Nov 2012 7:06pm
You missed this......
All good Thumbs Up
Post #154620 30th Nov 2012 7:14pm
Arenaitch
Yup missed it! But good stuff - and stop putting such tempting objects in front of me!
Glorious cars and that paddle shift is a delight - even down to the blip! 2012 FFRR Westminster Orkney / Ivory and absolutely no pimp-glass!
Post #154627 30th Nov 2012 7:25pm
