Home > Off Topic - Other Cars > Jaguar XK-R Sat NAV issues? |
Hi Guys I hope one of you electronic genius's can help me.
30th Nov 2012 4:11pm |
You can orient the Map true North or Direction but direction is obviously not the same direction as the car is going! |
30th Nov 2012 4:59pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Antenna or wiring between antenna and nav module at fault. |
30th Nov 2012 5:09pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
There should be a settings mode on it to allow you to see the satellite signal strength I would have thought. Previously..
30th Nov 2012 5:16pm |
Will have another fiddle tomorrow - very frustrating had a few Jags with this Nav and never seen this....
30th Nov 2012 5:20pm |
Probably similar to the setting the FF uses to re calibrate ====================================
30th Nov 2012 5:22pm |
Not being a SAT NAV expert Mick how do you get into that on a FF? |
30th Nov 2012 5:24pm |
Its been that long since i have done it Gaz i cannot remember off the top of my head
but its done via the settings menu
30th Nov 2012 5:28pm |
Maybe this guy might be able to help you as well Gaz
30th Nov 2012 5:32pm |
OK I think I have fixed it by re-cailbrating the system by moving the map until the cursor was sitting in exactly the current location and oriented in the exact right direction. I saved the setting and drove half way round the block and it worked but I thought this may be dead reckonning so I set my home as destination and it all worked tickertee boo.
30th Nov 2012 5:50pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8620 |
Thats a nice looking XK-R. There is nothing that can't be fixed with a hammerππ
30th Nov 2012 5:53pm |
Arenaitch Member Since: 27 Aug 2012 Location: Twixt Scummers and Skates Posts: 69 |
Traded my XK for the Westie. Must say I do think that the Jag touch screen / sat nav /menu / facilities / controls leaves the RR version in the shade.
30th Nov 2012 7:06pm |
You missed this......
All good |
30th Nov 2012 7:14pm |
Yup missed it! But good stuff - and stop putting such tempting objects in front of me!
30th Nov 2012 7:25pm |
