Home > Technical (L322) > Front Heated Seat Not Working... |
Bomber County Member Since: 12 Dec 2011 Location: Dunston, Lincoln Posts: 81 |
Hello all,
28th Nov 2012 7:49pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
first port of call would be to check the connections under the seat and the relevant fuse.. ... - .- -.
28th Nov 2012 8:02pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Stan, if the lights go on then all is connected correctly...
28th Nov 2012 11:43pm |
ok Craig , i thought that the lights might work but if the under seat connection is loose/faulty then it wouldnt work...
29th Nov 2012 8:16am |
right fellas that sounds like a start, thanks v much. - Ad augusta per angusta - |
30th Nov 2012 12:13pm |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 |
Bomber, did you find the cause of failure? I have similar fault on mine. Lights work, fan runs continually for couple of minutes, then stops. No heating or cooling. Was a replacement unit installed by main dealer about 4 years ago. 2007 TDV8 Vogue SE Java Black |
4th Jun 2013 7:33am |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Per his signature, Bombers car is a Vogue
4th Jun 2013 7:51am |
Thanks Graeme, good spot. indeed you are correct, it's a heated /cooled air system that I have.
4th Jun 2013 9:17am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 899 |
I have a similar issue with the drivers seat. The seat cooling works fine, but seat heating doesn't.
4th Jun 2013 11:26am |
Thanks for the link mpirie, and jpickie for the info. Will have a look into the seat gubbins when i get a chance. 2007 TDV8 Vogue SE Java Black |
4th Jun 2013 11:55am |
Arenaitch Member Since: 27 Aug 2012 Location: Twixt Scummers and Skates Posts: 69 |
Got these same symptoms on my 9m old Westminster, right after I've just had a loom issue found/fixed - I also thought it may have been simply a tugged connection, seems not though.
4th Jun 2013 12:30pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
Same problem here in mine Driver's seat cools ok and both red and blue lights work fine but it doesn't heat up.
4th Jun 2013 1:41pm |
My "lights are on but nothing happens" was apparently a "short in a motor under the seat' - whatever, it's fixed now. 2012 FFRR Westminster Orkney / Ivory and absolutely no pimp-glass!
12th Jul 2013 6:46pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
I found my drivers seat will heat if you select backrest only (immediately after turning the heat on), and cool both backrest and base without issue. If you just turn on the heat without selecting backrest straight away it has a sensor issue that makes the ECU cut the seat out. Turns out that heating is closed loop monitoring and cooling is open loop so cooling doesn't get temp monitored.
14th Jul 2013 11:41am |
