Home > Technical (L322) > Front bumper removal?
Johnte
I need to replace an inner front parking sensor. I assume the front bumper needs to come of Sad
Anyone done this? Any tips to make the job easier?
Thanks Thumbs Up
Post #151819 18th Nov 2012 12:02pm
mjdronfield
This is from RAVE. May be worth downloading from the Wiki if you don't have it.
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #151826 18th Nov 2012 1:24pm
I had to do this job. It's not hard at all. The most complex bit was unplugging the hose from the washer bottle and draining it out. It's simple as.
Obviously make sure you have something non scratching to put the bumper on when it is removed.
A little tip, use a cardboard box in front of the bumper to take the strain whilst you unhook all the electrics and the washer hose. Discovery 4 HSE
Post #151840 18th Nov 2012 2:49pm
Johnte
Thanks to both Thumbs Up Bow down
Post #151852 18th Nov 2012 3:25pm
When it's off it should look like this:
 Discovery 4 HSE
Post #151868 18th Nov 2012 5:07pm
Get a second pair of hands to help, that way when you unplug/plug the sensors, fogs etc the other person can hold the OS corner against the body whilst you do the NS and visa versa before it all falls on the ground ripping wiring out of plugs!
Another quick tip is to remove the fog light bulb rather than trying to unplug the fog light wiring...Much easier...
Craig Thumbs Up
Post #151879 18th Nov 2012 5:34pm
