Home > Technical (L322) > Front bumper removal? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
This is from RAVE. May be worth downloading from the Wiki if you don't have it.
18th Nov 2012 1:24pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
I had to do this job. It's not hard at all. The most complex bit was unplugging the hose from the washer bottle and draining it out. It's simple as.
18th Nov 2012 2:49pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
Thanks to both |
18th Nov 2012 3:25pm |
When it's off it should look like this:
18th Nov 2012 5:07pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16289 |
Get a second pair of hands to help, that way when you unplug/plug the sensors, fogs etc the other person can hold the OS corner against the body whilst you do the NS and visa versa before it all falls on the ground ripping wiring out of plugs!
18th Nov 2012 5:34pm |
