Home > Maintenance & Mods (L322) > Juddering in gear whilst at stand still |
m90got Member Since: 18 Oct 2011 Location: scunthorpe Posts: 120 |
Pulled up tonight to do a three point turn,put into reverse and felt it start to shudder a bit as if it was going to stall, gave it some revs and reversed them put into drive and it shuddered again, let it crawl and was still shuddering but this went away as i gave it some revs, when i came to a stop still in drive with footbrake on continued to shudder still as if would stall but the revs were ok.took it out again for a run and all ok untill i started to slow down, just before it reaches crawling speed it starts to shudder again!!!
7th Nov 2012 7:22pm |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 |
See these posts below, sounds similar to what mine does. The whole car shakes then goes back to normal;
7th Nov 2012 7:31pm |
Cheers i will give it a try , i was worried it was gearbox related !! Current Stable:
7th Nov 2012 7:41pm |
Exactly what went through my head. I'm still unsure but hoping land rover sort it under warranty. |
7th Nov 2012 7:50pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
Mine was exactly the same - turned out to be 2 injectors |
7th Nov 2012 8:31pm |
Did it just happen without any warning ? Current Stable:
7th Nov 2012 8:53pm |
