Home > Maintenance & Mods (L322) > Juddering in gear whilst at stand still
m90got
United Kingdom 2003 Range Rover HSE Td6 Alveston Red
Pulled up tonight to do a three point turn,put into reverse and felt it start to shudder a bit as if it was going to stall, gave it some revs and reversed them put into drive and it shuddered again, let it crawl and was still shuddering but this went away as i gave it some revs, when i came to a stop still in drive with footbrake on continued to shudder still as if would stall but the revs were ok.took it out again for a run and all ok untill i started to slow down, just before it reaches crawling speed it starts to shudder again!!!
Any ideas ?? Question Question Current Stable:
Range Rover 2003 TD6 HSE Alveston Red, Sand Leather
Ford Focus C-Max silver 2003
V/W transporter Blue 1995
Yamaha XJR1300 Yellow 2002
Kawasaki ZX7R Green 1998
Honda CBR 600 Black 1998
Yamaha RD125LC Mk1 Red 1986
Yamaha RD125LC Mk1 Blue 1986
Post #150150 7th Nov 2012 8:22pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
See these posts below, sounds similar to what mine does. The whole car shakes then goes back to normal;
http://www.fullfatrr.com/forum/topic14475.html
Someone else has similar to;
http://www.fullfatrr.com/forum/technical-vf2.html
Post #150151 7th Nov 2012 8:31pm
m90got
Cheers i will give it a try , i was worried it was gearbox related !! Current Stable:
Post #150152 7th Nov 2012 8:41pm
crookedm
Exactly what went through my head. I'm still unsure but hoping land rover sort it under warranty.
Post #150153 7th Nov 2012 8:50pm
Johnte
Mine was exactly the same - turned out to be 2 injectors Thumbs Up
Post #150157 7th Nov 2012 9:31pm
m90got
Did it just happen without any warning ? Current Stable:
Post #150162 7th Nov 2012 9:53pm
Johnte
Just gradually got worse - from hardly noticeable to bad Wink
I did try injector cleaner, it did work for a couple of months, but only a temporary fix..
Post #150172 7th Nov 2012 10:52pm
