Home > In Car Electronics (L322) > No telephone option listed on display
dirtyharry
Probably a dumb question, but being a new RR owner that's no surprise!
I thought that having found the telephone loom in the rear of the vehicle and wiring for a mike in the overhead console, this meant I should have the ability to retro-fit a BMW bluetooth ULF module and hey presto, I have telephone!
However, I am now wondering if this is the case, as my display (see image below) does not show "Telephone" as an option. Does this mean I am wasting my time fitting the ULF module? Or, will this option automatically appear as and when I correctly install a module? At the moment, I have the letters "DSP" where I expected there to be "Telephone".
Any tips/help would be appreciated as I find this all a bit confusing Embarassed
Cheers
Post #149837 5th Nov 2012 12:06pm
greatw
Dirty Harry, The option won't appear until teh ULF is installed and working as I ubderstand it. I'm just going through the same process. Microphone installed, ULF bought, just waiting for the plug to arrive at my local Audi dealer to re-pin the connector.
If you have the loom at teh back and the mic cable at the front, you should be good to go.
NOTE:- Do not plug the ULF directly into the loom on your FF. The pinouts are different and it needs adapting which, I am told is dead easy. I do hope so as I will be having a go on Wednesday evening.
There are far more knowlegable folks than myself who I'm sure will chip in, and welcone to the forum Smile
Cheers
Alex
Post #149843 5th Nov 2012 12:38pm
dirtyharry
Hi Alex
Comforting news! Thanks for confirming that, especially as I have already bought the module, mike and antenna! I've been sent the instructions to re-wire the 54-pin connector and am going to have a stab at it right now. I just wanted to make sure I wouldn't be wasting my time, but it looks like I won't be Very Happy
Cheers
Greg
Post #149845 5th Nov 2012 12:50pm
mjdronfield
Hi chaps.
Done this already..........
Telephone will indeed not appear in the display menu until the ULF has been identified on the ibus.
That is of course, if the ULF has not previously been plugged into the 54 pin plug without the rewire - that blows fuse 22 in the fuse box under the cd changer in the glovebox, and no matter what you do, Telephone won't appear till this fuse is changed and its 7.5 amp...........
I double checked my wiring twice, only to find that fuse blown...........
Let me know how you get on Greg. PM me again if you have issues........
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #149852 5th Nov 2012 1:49pm
dirtyharry
Thanks Mark.
Pm'ing you as we speak Wink
Cheers
Greg
Post #149857 5th Nov 2012 2:18pm
