Home > Technical (L322) > Key stuck in ignition
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
Hiya,
Help!! The key is stuck in the ignition in my 2005 s/c - any idea how I can release it? I've called 2 LR dealers and neither knows..
All assistance gratefully received! It's cold out 'ere....
Post #149516 2nd Nov 2012 6:29pm
Are you sure that 'Park' on the gear lever is properly engaged?
Post #149517 2nd Nov 2012 6:34pm
Squirrel
Yep, double-checked that. I'vebeen up and down the box , into Sport mode and back again, and I've tried waiting until the car's systems reset. Still no go. The red light is on to indicate Park mode, and P appears in the dash display. It looks like a sensor might have failed?
Post #149519 2nd Nov 2012 6:38pm
daveo
open your window first and make sure ignition is off.., then disconnect your battery for a few mins and then reconnect V8 facelift Range Rover Autobiography 22" wheels.
Post #149524 2nd Nov 2012 6:44pm
Lighty
Have you tried starting the car and driving round the block thus getting gearbox oil nice and warm and then trying to remove in case of faulty inhibitor switch?
Post #149526 2nd Nov 2012 6:45pm
any good?
http://www.fullfatrr.com/forum/topic9127.h...k+ignition ... - .- -.
Post #149527 2nd Nov 2012 6:49pm
Squirrel
I'm reluctant to reset the battery until an expert has had a look atit - I might break it properly if I do it myself. Wink
The car has just done a 40-mile run, so the oil should be hot. Smile there's a buzzing noise from the console, wonder if that's related? But it alwaysdoes that .
Post #149530 2nd Nov 2012 6:52pm
Lighty
Ok but id still try to drive it and get the oil moving just incase it is Censored in the inhibitor switch, ive had it before mate car thought it was in gear so wouldnt start kind of the other way round ffrom yours.
Post #149532 2nd Nov 2012 6:54pm
Squirrel
Stan, that looks promising - thanks! I'llgive it a go
Sorry for typos , BTW - im on my phone and my fingers are freezing!
Post #149533 2nd Nov 2012 6:55pm
daveo
how are you going to park it up,do you have a garage... V8 facelift Range Rover Autobiography 22" wheels.
Post #149534 2nd Nov 2012 6:56pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
The buzzing noise is a fan behind the mini grill next to the climate controls, it just blows air over the temperature sensor which is normal Thumbs Up
Post #149535 2nd Nov 2012 6:57pm
Squirrel
I'm sorted ! Smile
It was the fork next to the gear lever - I pulled up the leather surround and the following was jammed. I poked it and it released. And then the key came out. So I lubed up the whole mechanism and it works now. It's booked in for a service at the end of the month, so I might get them to give it a clean.
Thanks for all your help! Smile
Dave: i have a garage, but the Rangie doesn't fit it! I'dhave had tto have the car recovered to secure storage for the night if I hadn'tbeen able to fix it .
Would photos help anyone, when I'm back on my PC?
Post #149544 2nd Nov 2012 7:50pm
Squirrel
*following > fork! Drafted auto correct...
Post #149545 2nd Nov 2012 7:53pm
daveo
good news Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #149546 2nd Nov 2012 8:03pm
Squirrel wrote:
I'm sorted ! Smile
Glad we sorted it for you sir...
Craig Thumbs Up
Post #149566 3rd Nov 2012 12:42am
