Home > Technical (L322) > Key stuck in ignition |
Are you sure that 'Park' on the gear lever is properly engaged? |
2nd Nov 2012 6:34pm |
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 |
Yep, double-checked that. I'vebeen up and down the box , into Sport mode and back again, and I've tried waiting until the car's systems reset. Still no go. The red light is on to indicate Park mode, and P appears in the dash display. It looks like a sensor might have failed? |
2nd Nov 2012 6:38pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
open your window first and make sure ignition is off.., then disconnect your battery for a few mins and then reconnect V8 facelift Range Rover Autobiography 22" wheels.
2nd Nov 2012 6:44pm |
Lighty Member Since: 14 Oct 2012 Location: Manchester Posts: 7 |
Have you tried starting the car and driving round the block thus getting gearbox oil nice and warm and then trying to remove in case of faulty inhibitor switch? |
2nd Nov 2012 6:45pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35247 |
any good?
2nd Nov 2012 6:49pm |
I'm reluctant to reset the battery until an expert has had a look atit - I might break it properly if I do it myself.
2nd Nov 2012 6:52pm |
2nd Nov 2012 6:54pm |
Stan, that looks promising - thanks! I'llgive it a go
2nd Nov 2012 6:55pm |
how are you going to park it up,do you have a garage... V8 facelift Range Rover Autobiography 22" wheels.
2nd Nov 2012 6:56pm |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
The buzzing noise is a fan behind the mini grill next to the climate controls, it just blows air over the temperature sensor which is normal |
2nd Nov 2012 6:57pm |
I'm sorted !
2nd Nov 2012 7:50pm |
*following > fork! Drafted auto correct... |
2nd Nov 2012 7:53pm |
good news V8 facelift Range Rover Autobiography 22" wheels.
2nd Nov 2012 8:03pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16263 |
Glad we sorted it for you sir... Craig |
3rd Nov 2012 12:42am |
