Home > In Car Electronics (L322) > another sat nav problem |
try the other disc |
29th Oct 2012 1:09pm |
I know it sounds too simple but is this problem when stationary or when moving ? 2008 MY Supercharged
29th Oct 2012 1:17pm |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 952 |
cheers gaz
29th Oct 2012 1:26pm |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
When you say "stop" you don't mean that it's waiting for a space character before it will accept any more letters or numbers do you ? |
29th Oct 2012 1:28pm |
no, what i mean is that you can be typing in an address or postcode and the letter go grey so you cant select any..... |
29th Oct 2012 1:52pm |
well the plot thickens, as Axle suggested i tried the sat nav while stationary and it would seem that most of it worked with the exception of the post code part which still doesnt show the letters just the numbers, however when i started moving various parts greyed out? is this supposed to happen as i am sure it didnt happen before?
29th Oct 2012 4:36pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35427 |
'nav on the move' is greyed out on the 2010 disc upgrades...this can be unlocked using the IIDTool if you have the correct firmware.. ... - .- -.
29th Oct 2012 4:52pm |
i cant imagine that mine would have it being an 05 car? but i bought it in november 2010 so its possible but something must be wrong as teh letters are always greyed out when input via postcode..... does anyone know what the difference the latest disc might make? |
29th Oct 2012 5:01pm |
have you tried the other disc Andy? ... - .- -.
29th Oct 2012 5:04pm |
nope will try tomorrow, am guessing that i just have to take the old one out and add the new one? |
29th Oct 2012 5:25pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
If it's only showing numbers on the post code entry then it sounds likely that the search country is set wrong (probably Belgium if you've updated the disc) |
29th Oct 2012 5:28pm |
I'd forgotten about that one Martin (happened to me after driving back from Switzerland) - took a bit of head scratching to work out why the post codes were not working UK style! |
29th Oct 2012 10:19pm |
you guys were right on the money, was programmed to france! so all works now which is great (not that it was ever broken just me being stooopid)
31st Oct 2012 10:16am |
Yes, new maps. Depending on what year you've got now there may be a slight software update to the nav too, adding/updating some features. |
31st Oct 2012 10:29am |
