Home > Maintenance & Mods (L322) > 2012 Rear Led Taillight fitting
Page 4 of 4 <1234
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
I've said it here before, those boxes on ebay for 130 are absolute crap. They do not work right and certainly will not last!
Post #254325 14th Apr 2014 2:03am
That is why there are companies like mine around to do these conversions PROPERLY!!! Thumbs Up
Post #254335 14th Apr 2014 8:34am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Some like to have a go and save a few quid though and a lot like tinkering, I was an auto elec a few years ago but not tried yet as been ill a few years so works a long way off Sad _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #254393 14th Apr 2014 2:07pm
iansweetman
2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Cam-Tech-Craig wrote:
Should have a white sticker on top with NAS (north american spec) or ROW (rest of world) Thumbs Up
finallyremoving lights to have a look
here's the photos the first 2 photos are the passenger light which has the sidelight no foglight on and 3rd and 4th photos show the driver side that has foglight issue and no sidelight
can someone clarify which light is the correct one please!
Post #262327 30th May 2014 5:05pm
Before you make your choice of interface, I realise the indicator might flash really quickly, but should the LEDs on the new light still work? I got one off the bay and plugging it in. As expected the fog light is on and when I put the indicator on, the front flashed like mad, but the rear on the new light doesn't. Got - 2017 SDV8 Autobiography in Loire Blue
Post #279924 9th Sep 2014 1:52pm
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
so if you have an 05 AND touchscreen will they work?
Post #279925 9th Sep 2014 2:03pm
Before I throw my toys out of the pram at the flea by seller, can someone please confirm that a ROW rear led light should still indicate, albeit rapidly, without the interface box to sort this and other issues out?
The seller is also trying to tell me that because I have a UK car, a ROW light wont work, which I reckon is b'lox as there are only 2 types, NAS and ROW. Is this correct?
AFAIK, I could use either if I chose to have the side light on the NAS version? Got - 2017 SDV8 Autobiography in Loire Blue
Post #280374 11th Sep 2014 11:43am
iansweetman
As you can see I have one of each light on my vogue and only run one magic box and indicators flash normal just half fog syndrome on the one light without magic box on even if I connect second box on on the foglight stays on and box makes a buzzing noise so I leave it off. Its a brand new replacement from the seller as first one was the same, tried swapping them around onto the different lights and same outcome.
Post #280391 11th Sep 2014 2:29pm
jam220
United States 2007 Range Rover HSE 4.4 V8 Bonatti Grey
I have a 07 Full size rover and im in the States. I am doing a front and rear conversion. I see diff post with different info. One the 07, What do i need in order to make the front and rear lights fully functional? do you sell them kits? Thank you
Post #394663 5th Jul 2016 7:51pm
jam220
They dont work on a facelift 05 onwards Dave only pre facelift...
Craig Thumbs Up
So what's the solution you have for post 05 when you're doing your conversions?
With all due respect sir, that's what pays the bills...
Craig Whistle
hi sent you a message through your website to seeing if you have the conversion wiring front the front and rear..I have a 07 doing 2010+. Please let me know . Thanks
Post #395884 13th Jul 2016 4:30pm
does this help?
Post #395896 13th Jul 2016 4:56pm
...and rears,
http://www.fullfatrr.com/gallery/albums/us...lights.pdf ... - .- -.
Post #395898 13th Jul 2016 5:02pm
jam220
Great step by step article. I have 07, it says "The lights can be plugged in as the socket is the s
ame. On some ‘2007 on’ cars the lights will work fine but on the earlier cars there are se
veral problems" Assuming this info is correct all i need to do is replace the lights everything should work as it should?
As far as the light diagram, mine is 07 so will this apply for it as well?
Post #395920 13th Jul 2016 7:08pm
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
I'm thinking of doing this upgrade on my 03, will I need the interface boxes off eBay or just the resitors and fog light fix from powerful uk? 2004 RR 4.4 V8 Autobiography
Post #397863 26th Jul 2016 11:42pm
Page 4 of 4 <1234
