![]() | Home > In Car Electronics (L322) > another sat nav problem |
try the other disc |
I know it sounds too simple but is this problem when stationary or when moving ? 2008 MY Supercharged
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 965 ![]() ![]() ![]() |
cheers gaz |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
When you say "stop" you don't mean that it's waiting for a space character before it will accept any more letters or numbers do you ? |
no, what i mean is that you can be typing in an address or postcode and the letter go grey so you cant select any..... |
well the plot thickens, as Axle suggested i tried the sat nav while stationary and it would seem that most of it worked with the exception of the post code part which still doesnt show the letters just the numbers, however when i started moving various parts greyed out? is this supposed to happen as i am sure it didnt happen before?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35535 ![]() ![]() |
'nav on the move' is greyed out on the 2010 disc upgrades...this can be unlocked using the IIDTool if you have the correct firmware.. ... - .- -.
i cant imagine that mine would have it being an 05 car? but i bought it in november 2010 so its possible but something must be wrong as teh letters are always greyed out when input via postcode..... does anyone know what the difference the latest disc might make? |
have you tried the other disc Andy? ... - .- -.
nope will try tomorrow, am guessing that i just have to take the old one out and add the new one? |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
If it's only showing numbers on the post code entry then it sounds likely that the search country is set wrong (probably Belgium if you've updated the disc) |
I'd forgotten about that one Martin (happened to me after driving back from Switzerland) - took a bit of head scratching to work out why the post codes were not working UK style! |
you guys were right on the money, was programmed to france! so all works now which is great (not that it was ever broken just me being stooopid)
Yes, new maps. Depending on what year you've got now there may be a slight software update to the nav too, adding/updating some features. |
