Home > In Car Electronics (L322) > blank screen
reynolds
England 2004 Range Rover Autobiography Td6 Buckingham Blue
blank screen
Hi after 3 sleepless nights of worrying about car can anyone help my computer screen has gone blank radio cd all still work sat nav light is on in boot i have taken both plugs out of it still blank is now a good time to upgrade to digital or is there any thing else i can try to get screen displaying again my car is a 2004 range rover autobiography
Post #146939 19th Oct 2012 7:21am
When you say your computer screen, do you mean your computer (MPG, AV SPEED, DISTANCE ETC) or do you mean your nav screen? As you mention about removing the two plugs "which sound like the nav plugs to me"
If it is your Nav, then yes i would bin it and buy a MK4 DVD system my friend...
Craig Thumbs Up
Post #146941 19th Oct 2012 7:31am
might help..
http://www.fullfatrr.com/forum/topic8362.h...ank+screen ... - .- -.
Post #146942 19th Oct 2012 7:32am
reynolds
sorry i mean fuel clock ave speed radio dispay none are working
Post #146953 19th Oct 2012 8:17am
Still confused.
Are you saying that the Central Navigation/Info/Radio "Touch" screen is totally blank?
Post #146954 19th Oct 2012 8:25am
reynolds
it is not touch screen
Post #146962 19th Oct 2012 9:26am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Is it this screen:
Or the one in the bottom of the speedo?
Post #146970 19th Oct 2012 10:29am
reynolds
yes
Post #146981 19th Oct 2012 11:36am
Simes
I'm afraid you're being a little too enigmatic!
I asked and either or type question! Is it the one in the picture OR the one at the bottom of the Speedo etc?
Answer:
A - One in picture
B - One at the bottom of the speedo.
So - A or B?
Post #146983 19th Oct 2012 11:38am
This is getting a tad daft.....
Post #146989 19th Oct 2012 11:56am
Simes
It would help to know which screen if he wants any advice!
Post #146990 19th Oct 2012 11:57am
Going to be three more nights of worrying at this rate.... Surprised
Post #146991 19th Oct 2012 12:01pm
reynolds
sorry it is the one that controls the radio cd sat nav speed control the one under the speedo works but i cant reset any settings because the screen is blank i cant see what to do i dont car if sat nav or tv doesnt work as it is analogue i just wont the controls to be displayed for every thing else sorry about the last reply as i did not see the other question at bottom of picture
Post #146992 19th Oct 2012 12:03pm
What you need to initially is this,
Remove side panel on passenger side of boot.
Wait until red light on satnav goes off and release unit from cradle.
Un-plug the red and blue plugs and aerial connections.
Move sat nav out off way.
Un-plug the blue and white plugs from the tv module.
Refit red plug to sat nav.
Fit blue plug from tv module to blue socket on sat nav.
Refit aerial to sat nav.
You will need to move the sat nave to a position above the tv tuner to do the above, the cable on the tv tuner blue plug is very short.
You have now bye-passed the redundant tv tuner.
Switch the ignition on and let's know what happens.
Post #146994 19th Oct 2012 12:15pm
reynolds
ill check that later but can you disconnect the sat nav aswel as the tuner?
Post #146998 19th Oct 2012 1:00pm
