Home > Technical (L322) > L322 4.4 Gearbox recon / repair Manchester |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
try land ranger in stockport have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
13th Oct 2012 10:17am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 980 |
What exactly is your 5HP24 doing that it shouldn't be doing (or not doing that it should be)?
13th Oct 2012 1:16pm |
red_slr Member Since: 06 Oct 2010 Location: Manchester Posts: 42 |
If it does not require any diag kit then quite probably can remove myself.
13th Oct 2012 6:46pm |
All of those issues sound lock-up clutch related. The LUC is preloaded ‘on’ by these tangential springs
13th Oct 2012 7:52pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Phil, don't have any problems but so pleased your on this forum. You knowledge and understanding is second to none! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
13th Oct 2012 8:41pm |
Yes I agree with Rob, a real asset to us lesser beings, just a shame you don't do the TD6 box |
13th Oct 2012 8:46pm |
Thanks Phil. Are any special tools required for removal of the box or TC? I have RAVE. I have a lot of tools - so I guess I might be ok. Thanks again! Range Rover Vogue 4.4 (2003) |
15th Oct 2012 8:56am |
jdog30014467 Member Since: 29 Jan 2014 Location: north london Posts: 6 |
hi there im new to this site and have been reading through your posts and it seems like your the man I need to talk to im not to sure how it works so hopefully am posting in the right place. Here goes ibought my rr 4.4 v8 recently and it vibrates when I get to 25 mph 1500 rpm [ cattlegrid effect ] it only happens at low throtle in third gear but disappears after 40 mph and doesn't happen in manual/sport ive read a lot of these threads and this sounds like torque converter failure ! all my gear changes are fine so im hoping ive caught this problem early also there is no judder whenim in manual/sport my car has down 125000 miles and I don't think the box has ever been touched before , could anyone tell me the process of how to pinpoint the exact problem pls or any other relevant info would be much appreciated thanks. 2003 range rover se autobiography 4.4 v8 |
29th Jan 2014 10:24pm |
You need to watch your rev counter needle closely while it’s making the cattle grid noise to see if it moves up and down (only by 100 rpm or so) in sympathy with the noise. If it does, you have a lock-up clutch problem with your torque converter and it needs to be replaced.
30th Jan 2014 11:53am |
hi and thanks for the reply ,yeah it seems like when the vibrating starts the needle stays still for a second or 2 then jumps up a bit but only by about 100rpm like you said. Would you say I need a my converter recond ? and also someone has suggested just getting the whole gearbox done but thatll be pricey so if I can get away with it id rather not what do you think,thanks |
31st Jan 2014 10:16am |
