Home > Technical (L322) > Oil change in diff's
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Is it worth changing the oil in the front and rear diff's
If so what's the correct oil and best place to buy from RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #145648 9th Oct 2012 7:17pm
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
go on wiki top of web page and go to lubricant Thumbs Up
Post #145677 9th Oct 2012 8:15pm
Jr-auto-electrics
Thanks
Little confused
It's recommends the same texaco oil for front and rear diff
But different for castrol??
Think ill ring local stealers in the mornin
So will I notice any thing changing these oils???
Or just good practice RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #145691 9th Oct 2012 9:02pm
simonmanx
yes i noticed that i guess its the closest to the spec but some companies have a spec that cover several spec i guess give the spec to suppliers and see what they have in stock. their online supplier should find a match
Post #145692 9th Oct 2012 9:05pm
csjxx
United Kingdom 2004 Range Rover Vogue 4.4 V8 Zermatt Silver
I cant find it on wiki. Will the lubricants be the same on a 4.4 V8?
Thanks
Post #145775 10th Oct 2012 10:09am
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
JR
I asked a similar question a few months back (Cant find the post now), have a search
One handy tip I picked up was to ensure you loosen the fill plug first, incase you drain the diff then cant undo the fill plug Big Cry
Havent got round to doing it yet though
Post #146036 11th Oct 2012 7:58pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I replaced the transfer box oil and oil in both diffs today in my 4.2 S/C.
Based on the stuff that came out, there is a very strong case for replacing these more regularly than recommended. I understand the recommended interval is 150k. Mine has just done 150k and the oil was badly burnt and degraded, separating out into two layers in the container after they were drained.
The magnetic drain plugs we covered in a thick waxy black deposit some 5mm thick as well assome metal filings.
The changes are easy to do and well worth it.
Post #183804 20th Apr 2013 5:40pm
MikeG
Netherlands 2007 Range Rover Vogue TDV8 Santorini Black
Planning to do mine in the next couple of weeks as well... Have the FFRR for about a month now and so far no complaints but will conduct some preventive maintenance soon. Next to the diff's will tackle the gearbox as well... Better safe then sorry and also curious to how the fluids look like since I do not know if they have been changed before. Mike.
2007 Range Rover Vogue TDV8, Black, Sand Leather Seats & Sand / Black Interior.
IID Tool from GAP Diagnostics.
Post #183806 20th Apr 2013 6:13pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Just had mine done as part of last service, even though according to the service sheet it's a 10 year interval item.
They hold 1.1 litres of oil I was advised but my service bill showed 2 litres.
Part number listed is IYK500010 £15.61+VAT per litre.
(2007 TDV8)
Hope this info helps
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #183812 20th Apr 2013 6:33pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Jr............for the Diffs just use a good 75w90 API GL-5 oil, like.......Triple QX EP 75w90 Transmission Fluid Fully Synthetic 1 Litre (1L) API GL-4 GL-5.......you can ge this for less than £8 a litre........dont get too hung up on the make of oil its whats inside that counts just check the label
Post #183857 20th Apr 2013 9:25pm
RRBlue
I bought my oil from the dealer by the litre.
The transfer box oil was labelled as Transfer box oil. The diff oil just had auto transmission oil on the label. Both were genuine LR oils.
Post #183940 21st Apr 2013 6:25pm
FYI the transfer box seems to have a marker that works out when it's at 100% life, mines showing 80% currently but I wouldn't bet on it being totally right and I reckon only 2 or 3 diagnostic tools can reset that number Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #183978 21st Apr 2013 10:55pm
