Home > In Car Electronics (L322) > What is this? a picture included
alahmed
Saudi Arabia 2004 Range Rover HSE 4.4 V8 Bournville
Hello
how are you guys
i want to ask about something in the next picture
what is that? Question
http://www.flickr.com/photos/78049469@N06/.../lightbox/
Post #144074 1st Oct 2012 8:18pm
BrianC
I think it's the sensor for the auto climate control
Post #144075 1st Oct 2012 8:22pm
Looks like your PC screen to me Laughing Laughing
Post #144084 1st Oct 2012 8:43pm
Ignore John Wink
It detects the amount of "sunshine" outside the car and this helps to make adjustments to the climate control inside e.g. if full sunshine supposed to make things work harder to maintain temperature/perceived comfort, if cloudy, no need to work so hard to maintain a comfortable internal environment .
Post #144086 1st Oct 2012 8:54pm
mjdronfield
I've never got this.
If the sun is out, it tends to be hotter, so the car will have to work harder anyway as the interior will be hotter. (if you are cooling - obviously)
If its cloudy, its cooler, so won't have to work as hard.
Can't the temperature sensors in the car be enough ?
Obviously the sunlight detector does something, as they wouldn't be fitted.
I'm not Captain Climate, no idea how they work, but I must be missing something........
Perhaps its not just the temperature...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #144160 2nd Oct 2012 9:52am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I think the point of the sunshine detector is that when the sun is shining through the windows, the perceived temperature will be higher in the car due to the warming effect of the sun shining on your clothes etc. Therefore the Climate Control drops the air temperature a couple of degrees to offset this.
Post #144423 3rd Oct 2012 8:15am
mjdronfield
Sneaky car - thinking for itself !!
For years you'd be able to beat an ABS system by cadence braking yourself, but in the last few years, you can't anymore.
Just shows you how things progress.
Climate Control is no different I suppose. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #144452 3rd Oct 2012 10:27am
