Home > LPG > What plugs?
SparkyPhil
England 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
What plugs?
I have a 2005, 4.4 with a BRC lpg system fitted, which is due to have the plugs replaced. I would like to know what plugs other people have/are using and if you rate them?
Kind Regards Phil
Post #142534 22nd Sep 2012 7:48pm
cass
I can highly recommend NGK plugs - I've used them on a whole host of LPG cars and always found them better at eliminating misfire faults that showed up with other makes.
They make an LPG specific plug now but I've never tried them, the normal plugs always lasted well so I suppose the choice comes down to price.
Post #142574 23rd Sep 2012 12:22pm
klf400
i have run lpg range rovers for the last 10 years , and run 2 at the moment i have allways used the standard plugs with no problems at all , however regular sevicing is allways top of the list Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #142607 23rd Sep 2012 7:11pm
There are usually higher temp plugs I have found in the past to last twice as long as normal plugs in other cars and worth the money but if std plugs work maybe save the cash Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #142612 23rd Sep 2012 7:59pm
SparkyPhil
Cheers for the replies.
Phil
Post #143384 27th Sep 2012 7:36pm
D16XEY
Scotland 2003 Range Rover Vogue 4.4 V8 Java Black
Spark plugs
Brisk silver, all you need to know
Post #219579 29th Oct 2013 8:56pm
roadnutter
Hi,
I run my 2003 4.4 Vogue on the standard plugs and they last perfectly. Never any issues. About £16 for all 8 delivered
http://www.ebay.co.uk/itm/NGK-spark-plug-B...3a452cf8f1
James
Post #258012 7th May 2014 10:57am
