![]() | Home > LPG > What plugs? |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 753 ![]() ![]() |
I can highly recommend NGK plugs - I've used them on a whole host of LPG cars and always found them better at eliminating misfire faults that showed up with other makes.
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
i have run lpg range rovers for the last 10 years , and run 2 at the moment i have allways used the standard plugs with no problems at all , however regular sevicing is allways top of the list |
There are usually higher temp plugs I have found in the past to last twice as long as normal plugs in other cars and worth the money but if std plugs work maybe save the cash |
SparkyPhil Member Since: 29 Oct 2011 Location: Staffs Posts: 59 ![]() ![]() ![]() |
Cheers for the replies.
D16XEY Member Since: 29 Oct 2013 Location: Broughty Ferry Posts: 20 ![]() ![]() ![]() |
Brisk silver, all you need to know |
roadnutter Member Since: 19 Sep 2013 Location: Bridge Of Weir Posts: 23 ![]() ![]() ![]() |
Hi,
