![]() | Home > Maintenance & Mods (L322) > TD6 Has a shudder |
uteman Member Since: 23 May 2012 Location: Newport, Victoria Posts: 11 ![]() ![]() ![]() |
There may be some folk out there who have remembered the saga of my TD6 engine which has all sorts of issues following a dose (or doses) of diesel fuel that was blended with animal/vegetable oil plus it had 22 times the allowable limit of moisture.
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
Has all the softwares been updated to latest for engine and gearbox ? onto no6 Range Rover
What exactly do you mean by "updated?" |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
When my TD6 suffered juddering issues it was tracked down to a faulty low pressure fuel pump, the one that is external to the tank mounted on the chassis.
I thank you for your response.
From Uteman: 3rd October 2012: I checked with Land Rover and there have only been software updates for later models but thanks for the suggestion. |
