Home > Technical (L322) > SUSPENSION FAILURE!!!!!!
ricknayton
United Kingdom 2006 Range Rover Vogue SE Td6 Santorini Black
I have a 55 plate Range Rover Vogue and have just had 'Suspension Failure' flash up on the dash. There is hissing coming from the off side front. It is now warning not to go over 30 miles per hour. Does anyone have ideas on how much this should cost to repair? Is it common? Would really appreciate all your help.
Post #116944 9th Apr 2012 2:05pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
I just did mine last weekend, about £227+vat for the new air suspension strut and 1.5 - 2 hours work.
It is about 7 bolts. I am useless at DIY, but had a go anyway.
Youtube video instructions below, thanks to Storey
&list=UUWHaoEnaTm4c6g6raTn-5dg&index=4&feature=plcp
P.S. nice to meet you Rick 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #116947 9th Apr 2012 2:49pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
All the common symptoms of air suspension failure.. "Suspension Failure" error msg and hissing Laughing
Cost wise, it could be anything from a broken air pipe to a complete air spring, new air spring are ~£350 each so £380 to £450 for the complete repair at a garage.
If it is the air spring, I'd recommend getting them done in pairs Thumbs Up
Post #116948 9th Apr 2012 2:53pm
ricknayton
Thanks a lot for your help. I have just spent £1000 on the rear bushes and some other faults that were found when it was plugged in! Was hoping that would be it for a while at least. Seems not. Crying or Very sad
Post #116950 9th Apr 2012 3:11pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
if you put the car into off road mode to extend the air springs and either use your hand to feel for air or spray some fairy liquid solution over it to see if any bubbles appear, you will know if it is a hole in the air bag itself.
you got to start somewhere!! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #116972 9th Apr 2012 5:29pm
ricknayton
Thanks for that. I will give it a go.
Post #116976 9th Apr 2012 6:20pm
SteveMFr
Site Sponsor
And if you need it, I'm pretty sure these guys have the best prices on struts
http://www.island-4x4.co.uk/spring-front-r...-1254.html
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
(wife thinks I'm nuts - prob right, too)
Post #117049 10th Apr 2012 2:42pm
ricknayton
Hi Steve,
Thanks a lot for that. RR were after £550!!! Saved a few £££ there. Will get you a beer.
Thanks again. Smile
Post #117207 11th Apr 2012 4:16pm
SteveMFr
Site Sponsor
Mmmmm, beeer.
Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #117283 12th Apr 2012 6:57am
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Steve I have to replace my OS front as well. Seen on Island4x4 that they do a Dunlop air spring for 185 (ex vat).
My question is are these any good or should I stick with the Delphi?
Post #136059 15th Aug 2012 5:59pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
I know the bloke who is in charge of the r + d at dunlop and he designed and tested the struts they make and they are better than delphi in terms quality from what ive seen and they are made in coventry next to were parts for airbus and stuff are made I personally would change the pair so they match charectoristically onto no6 Range Rover
Everyone needs a hobby
Post #136117 15th Aug 2012 9:14pm
Bob the B
Thanks speedy Im just off to order a pair now and hope for some nice weather to fit them Thumbs Up
Post #136199 16th Aug 2012 11:34am
