![]() | Home > Technical (L322) > SUSPENSION FAILURE!!!!!! |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 ![]() ![]() ![]() |
I just did mine last weekend, about £227+vat for the new air suspension strut and 1.5 - 2 hours work.
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
All the common symptoms of air suspension failure.. "Suspension Failure" error msg and hissing |
ricknayton Member Since: 07 Apr 2012 Location: Essex Posts: 29 ![]() ![]() ![]() |
Thanks a lot for your help. I have just spent £1000 on the rear bushes and some other faults that were found when it was plugged in! Was hoping that would be it for a while at least. Seems not. |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
if you put the car into off road mode to extend the air springs and either use your hand to feel for air or spray some fairy liquid solution over it to see if any bubbles appear, you will know if it is a hole in the air bag itself.
Thanks for that. I will give it a go. |
And if you need it, I'm pretty sure these guys have the best prices on struts
Hi Steve,
Mmmmm, beeer.
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
Steve I have to replace my OS front as well. Seen on Island4x4 that they do a Dunlop air spring for 185 (ex vat).
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
I know the bloke who is in charge of the r + d at dunlop and he designed and tested the struts they make and they are better than delphi in terms quality from what ive seen and they are made in coventry next to were parts for airbus and stuff are made I personally would change the pair so they match charectoristically onto no6 Range Rover
Thanks speedy Im just off to order a pair now and hope for some nice weather to fit them |
