Home > Technical (L322) > SUSPENSION FAILURE!!!!!! |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
I just did mine last weekend, about £227+vat for the new air suspension strut and 1.5 - 2 hours work.
9th Apr 2012 2:49pm |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
All the common symptoms of air suspension failure.. "Suspension Failure" error msg and hissing
9th Apr 2012 2:53pm |
ricknayton Member Since: 07 Apr 2012 Location: Essex Posts: 29 |
Thanks a lot for your help. I have just spent £1000 on the rear bushes and some other faults that were found when it was plugged in! Was hoping that would be it for a while at least. Seems not. |
9th Apr 2012 3:11pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
if you put the car into off road mode to extend the air springs and either use your hand to feel for air or spray some fairy liquid solution over it to see if any bubbles appear, you will know if it is a hole in the air bag itself.
9th Apr 2012 5:29pm |
Thanks for that. I will give it a go. |
9th Apr 2012 6:20pm |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
And if you need it, I'm pretty sure these guys have the best prices on struts
10th Apr 2012 2:42pm |
Hi Steve,
11th Apr 2012 4:16pm |
Mmmmm, beeer.
12th Apr 2012 6:57am |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 |
Steve I have to replace my OS front as well. Seen on Island4x4 that they do a Dunlop air spring for 185 (ex vat).
15th Aug 2012 5:59pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
I know the bloke who is in charge of the r + d at dunlop and he designed and tested the struts they make and they are better than delphi in terms quality from what ive seen and they are made in coventry next to were parts for airbus and stuff are made I personally would change the pair so they match charectoristically onto no6 Range Rover
15th Aug 2012 9:14pm |
Thanks speedy Im just off to order a pair now and hope for some nice weather to fit them |
16th Aug 2012 11:34am |
