Home > eBay & Bargain Spots > Heatshot - Heated washer jet system great price |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
The Heatshot is an aftermarket system that creates a reserve of hot water in your washer system so when you need to clear ice bugs the warm water speeds up the process.
7th Aug 2012 6:53pm |
Looks okay , think i'll stick with my heated jets tho .. |
7th Aug 2012 7:05pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35411 |
wouldnt a cold screen and hot water spraying onto it cause a bit of a problem.. ... - .- -.
7th Aug 2012 7:20pm |
Well it is 50 degrees so not boiling and it seems to work well according to lots of reviews on Defender and Discovery forums.
7th Aug 2012 7:29pm |
warm water on a frosted screen does work wonders...let us know how it all works out TOM.. ... - .- -.
7th Aug 2012 7:39pm |
Will do! Tom
7th Aug 2012 7:42pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6734 |
Heated windscreen anyone? Got - 2017 SDV8 Autobiography in Loire Blue
Thats Right forgot about that and the FBH |
7th Aug 2012 7:44pm |
Ok guys, I understand that all of you with 10-30 minutes on your hands can prep the car with the FBH and heated screen. But in my experience, if I need to suddenly use the car and don't have time to wait then the FBH and heated screen are far too slow.
7th Aug 2012 7:54pm |
7th Aug 2012 7:57pm |
To be honest it won't be 50'c when it hits the screen so should be fine and the heated elements do the same, col screen quickly being heated above 0'c same affect really
7th Aug 2012 8:07pm |
You'll all be jealous as I steam past you.....
7th Aug 2012 8:32pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
10-30mins... So how long will it take your element to melt/heat the screen resevoir before the washers will work my friend? Craig Last edited by Cam-Tech-Craig on 7th Aug 2012 11:10pm. Edited 1 time in total |
7th Aug 2012 11:07pm |
It would depend on the element
7th Aug 2012 11:09pm |
