Home > Technical (L322) > Air suspension compressor
Windscreen Dave
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
I am repalacing this on Friday anybody got any advice or tips. I have 2004 vogue diesel also doing front suspension air bags both jobs look fairly straight forward but as always landrover put there hidden gems in to catch you out. Smile
Post #132963 25th Jul 2012 9:49pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Dear Dave, very easy job, believe me, have done it several times, you can first go to youtube, and search for videos from RSW Solutions, the good Storey Wilson shows you the repair of struts, airbags and so on. The compressor to change, first take out your fifth wheel, than open the four screws on the floor, take away the cable for power and the pipe for the air, and than change it. Afterwards you must clear a fault with a RSW or GAP Reset tool, or you take away 12V power from the car before!!! you open the cable connection, then you have not to clear faults. If questions, ask me,
regards, Meerbusch L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #132967 26th Jul 2012 5:39am
Windscreen Dave
Thanks very much Meerbusch. Thumbs Up
Post #132971 26th Jul 2012 6:54am
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
I was also advised by a LR mechanic to change the relay when I did mine - cost me £6.77 +VAT. l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #132989 26th Jul 2012 8:13am
Meerbusch
@T111RDY, very good input, yes, it is little money, because sometimes the relay is defct for the 3-Minutes-time. But please say to us, dear T111RDY, what of the three relays, all are green, is it in the luggageroom?
Happy day!!! L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #132992 26th Jul 2012 8:30am
Windscreen Dave
Job done both front airbag struts and compressor took about 3 hours In between changing windscreens not a bad days work. Compressor as stated really easy, the front struts were easy just time consuming removing solid bolts, lots of wd..
Post #133286 27th Jul 2012 6:09pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Swapping out air compressor
Just want to confirm with everyone that the air compressor is that easy to change on 06my vogue?
Remove spare wheel, unbolt, change, and reset faults?
Save me a few bob going to the stealers.
Thanks
Post #136020 15th Aug 2012 1:04pm
Andy
I bought a new relay when I rebuilt my compressor- where does that relay go? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #136350 16th Aug 2012 8:37pm
Lolo
Bump Bow down
Ill have an old compressor if anyone interested for their own rebuild project or whatever..
Post #136351 16th Aug 2012 8:49pm
Meerbusch
Hallo, I am very interested....
Best regards, Meerbusch L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #136365 16th Aug 2012 9:53pm
Lolo
Ok but can u tell me if my summary of changing out the compressor is correct?
Thanks
Post #136368 16th Aug 2012 10:00pm
Meerbusch
@ Lolo, yes, it is correct, remove wheel, then the 4 bolts on the floor out, then the electric cable and the plastic-pipe for the air (bajonett pushing), very easy job. If you have a new one with shape, you can change direct, if without shape, three bolts and the white plasichholder open and change then. Afterwards clearing the faults with one of the 3 softwaretypes...
Many regards, Meerbusch L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #136437 17th Aug 2012 8:46am
Lolo
Ok so my dad change out my compressor for me, few questions,
It was soaking wet in there, would that have affected the compressor?
What's the nipple thingy for? Cause my old one was a lot more worn than the one?
So suspension now works but when I put in offroad height I hear a hissing back strut. I was told by my LR indy that it's very rare for the back bags to leak. Is that true?
Final question, car does not be lob sided in normal mode after left parked, how long u reckon my compressor will last. Score it burns out filling up the bags? Is it urgent to get new strut u think?
Thanks :bow:
Post #136583 17th Aug 2012 7:55pm
Lolo
Bump Thumbs Up Shocked Bow down
Post #136760 19th Aug 2012 12:31pm
That brass nipple is your sintered brass air filter not sure I can answer you other questions . 2008 MY Supercharged
Post #136763 19th Aug 2012 1:11pm
