Home > Maintenance & Mods (L322) > Poll. What pressure cap is fitted to your M62 V8 |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
There is a lot of confusion about what is correct.
26th Jun 2012 8:12pm |
Once you have had black you will never go back! 200 on mine. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
26th Jun 2012 11:33pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
200 on mine too - August 04 BMW petrol 4.4
27th Jun 2012 4:13pm |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
Mine has the yellow insert.
29th Jun 2012 4:04am |
The design could be to reduce emissions and not because it is "better" for the engine. Not saying that it is like that here but could be. Same with the fuel system programming, they are based on improving the emissions (based on the standard tests) and that is not always optimum driveability. MY 2010 5.0 SC Galway green and sand interior!!
30th Jun 2012 2:29pm |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
140 on mine. 2003 . Gulp should I be worried? 2003 Vogue 4.4 V8 Java Black |
30th Jun 2012 7:01pm |
Do you have any problems at 140? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
30th Jun 2012 8:27pm |
It's on it's second engine! Due to overheating (previous owner replaced the engine) . Current engine sits in the middle of temp guage and doesnt move a bit. Does seem to use a very small amount of coolant though (its also had a very recent water pump, rad and hoses so i know they're not leaking - maybe time to upgrade to stop the minor loss but on the flip side though I don't want to fit a higher pressure cap and blow some hoses! 2003 Vogue 4.4 V8 Java Black |
30th Jun 2012 8:44pm |
