Home > Technical (L322) > Airbag light on..
Andy
Airbag light on..
For some unknown reason, when I started the car today at the petrol station, the airbag light came on and has stayed on since.
How do I turn it off? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #8907 30th Nov 2009 10:04pm
Not got a clue .......
Post #8909 30th Nov 2009 11:01pm
dantheman
I'd say you'll need to establish whether there's a fault in the SRS system by using a diagnostic tool. A common fault/weak point on several cars that I've worked on or owned (my Alfa was a Censored for it) seems to be the connector beneath driver or passenger seat: it moves when the seat slides back and forth which tends to deteriorate the connection between cable and plug, and is also prone to damage by passengers' feet when sat in the back. But then, it could be anything... Shocked
Would be interested to hear the outcome.
Post #8910 30th Nov 2009 11:04pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Does the seat heating work? I have the SRS light on and seat heating isn't working and the dealer in my town said he cannot communicate with the airbag computer? I have to take the car to another dealer 400km away...
Post #8913 1st Dec 2009 8:02am
Andy
Yeah, the seat heating works fine. I did reset the trip meter when I refueled. Might have spiked the electrics or something.
Oh by the way Mick- you ain't funny. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #8914 1st Dec 2009 8:09am
Remove the fuse for airbags and replace...just a thought? (you can tell I'm not technical) Discovery 4 HSE
Post #8932 1st Dec 2009 1:54pm
Embarassed Embarassed Bow down
Post #8944 1st Dec 2009 3:52pm
The Flying Scot
Scotland 2012 Range Rover Westminster 4.4 V8 Fuji White
Noddy,
This happened to mine earlier this year. The Airbag SRS light just came on one day for no apparent reason. I took it to Dealer who lug in the diagnostics and said there was a fault with the firing loom on the drivers airbag. They reset it and it was fine for a few weeks. When it came on again they did another diagnostic test and same fault was shwon. They could not pin point the exact component failure but guessed it was the rotary coupler on the steering wheel. I asked them for a quote but still waiting. In the meantime I'm told all the airbags are disarmed whilst the light is on..bit scary!
let us know what you un-earth as I'm keen to get to the bottom of this also.
Cheers 2011 Range Rover TDV8 4.4 Vogue SE
2007 Range Rover TDV8 Vogue (Sold)
2004 Range Rover Vogue TD6 (Sold)
Post #8955 1st Dec 2009 7:54pm
Found this on another forum ..........
http://www.landrovernet.com/forum/showthread.php?t=52862
Post #8957 1st Dec 2009 9:14pm
