Home > General > How much body roll is normal in corners?
Page 2 of 3 <123>
ahebron
New Zealand
I do find the FFRR rolls a bit more than my old 300TDi Disco which in turn rolled more than my 110 County V8. But I find it more reminiscent of the Rover P6 V8 and Fiat 130 V6 that I used to own, when cornering in those you would lean the car over and they would corner very well but with ridiculous body roll.
Adrian VW Amarok 2014 Highline auto
Post #128499 29th Jun 2012 11:18pm
Yes they do roll, great fun if you are the driver but not the passenger Laughing Laughing
Post #128501 29th Jun 2012 11:20pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
Cross-linked air suspension only works when the vehicle determines it is "off road".
RAVE wrote:
The air suspension ECU senses that the vehicle is off-road by comparing rapid changes in signals from the height sensors. The operation of the cross-link valves is fully automatic, requiring no driver intervention.
The cross link valve operates only in off road mode and its operation is governed by the off road mode speed threshold.
RAVE also wrote:
The system will temporarily inhibit height adjustments when the vehicle is subject to cornering, heavy acceleration or heavy braking. The inhibit function prevents unsettling of the vehicle by reducing the effective spring rates.
The vehicle determines "cornering, heavy accelation or heavy braking" based on a sensor in the center console.
If that sensor is faulty, it may cause problems.
This sensor also feeds the DSC system, which will selectively brake individual wheels and/or reduce engine power to help reduce unstable conditions in turns.
I haven't owned a "car" for more than 15 years; I don't even remember what it feels like to drive something with a center of gravity closer to the ground than 4 feet... Smile Jim
2000 NAS HSE
2005 NAS HSE
Post #128510 30th Jun 2012 1:55am
farrellelion
Portugal 2002 Range Rover Vogue Td6 Java Black
I was unhappy with the rolling of my 2002 FF on first usage.But now, I find that I easily loose those suppositories up my tailpipe.I find it a well balanced vehicle, but you must corner in MANUAL MODE . Change down, and accelerate hard through the corner-- a Porsche mechanic once told me he loved the 911's behavior in a corner - don't be afraid, if you are in the correct gear(only possible in manual), the more you crap yourself, the harder you stand on the gas. I'm amazed at the cornering ability of this TD 6 .This is aided by good tires and there's no wallowing effect. In automatic however, you shouldn't be going at speeds that cause much roll, the ride is definitely on the soft side. 2002 Vogue TD6
2001 Defender 90 TD5
Range Rover Classic 1994
Mercedes Benz 220 S Sedan 1959.
Post #129083 2nd Jul 2012 11:51pm
RenoHuskerDu
France
I will try using manual mode to corner today. Shock absorbers are also suspect in this vehicle. I will dig thru the dealer service records soon and see if they have been renewed yet. Reno, on assignment in France.
Post #129091 3rd Jul 2012 7:52am
ebajema
Just get an S/C, they corner quite nicely Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #129124 3rd Jul 2012 9:22am
^^^ Sideways Shocked
Post #129128 3rd Jul 2012 9:25am
if you do decide to purchase this fullfat then consider investing in steve's IIDTool which will allows you to lower the suspension so that it handles better around corners..member DMRR has done this ... ... - .- -.
Post #129129 3rd Jul 2012 9:25am
RenoHuskerDu
France
Is there truly a difference in the suspension of supercharged models? Reno, on assignment in France.
Post #129157 3rd Jul 2012 11:19am
DMRR
S/C has stiffened anti rollbars, the same has been achieved on my TDV8 with a 15mm lowering all round. I would say my TDV8 handles better now than my previous 5.0SC and 4.2SC. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #129159 3rd Jul 2012 11:28am
ebajema
http://www.rangerovers.net/modelspecs/L322/2006.html
According to this and other articles I have read, the S/C are set up for "going faster". Mine handles very well but to be honest I hardly ever (get a chance to) use it. MY 2010 5.0 SC Galway green and sand interior!!
Post #129160 3rd Jul 2012 11:28am
RenoHuskerDu
France
"Less publicized was the fact that as a result, wheel travel on the Supercharged model was reduced form 10.75 to 7.5 inches at the front, and 13 to 11 inches at the rear."
Everything in this world comes at a cost. If actual wheel travel was reduced, then the car is not just simply sitting lower. The suspension geometry was changed. Interesting, more like an L320, eh? Reno, on assignment in France.
Post #129165 3rd Jul 2012 11:36am
DMRR
Caused by stiffened anti-roll bars Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #129169 3rd Jul 2012 11:43am
ebajema
I can't compare the two as I have never driven a RRS (been in one but that is different). The S/C is very fast for a heavy lump and handles much much better than I am used of big heavy cars (Toyota Landcruiser, GMC Vandura etc.). I personally don't care about reduced suspension travel as I don't need it with my S/C.
Considering the test reports worldwide on the FFRR, the reduced travel does not seem to have reduced the fact that the FFRR is still considered the best 4WD in the world Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #129170 3rd Jul 2012 11:44am
RenoHuskerDu
France
DMRR wrote:
... Caused by stiffened anti-roll bars Smile
Strictly speaking, unless the A/R bars are structural links in the suspension geometry or something along those lines, then stiffening them should have no effect on wheel travel at all. Unless of course you hold one wheel in a fixed position and measure only the travel on the other side Laughing but that would be python-esque parody now wouldn't it. As our yank friends would say: just sayin' - not trying to pick nits.
But seriously, if there is less travel, then it's not just A/R bars that they tweaked. Now I'm curious. Reno, on assignment in France.
Post #129180 3rd Jul 2012 12:26pm
Page 2 of 3 <123>
