Home > Maintenance & Mods (L322) > Battery drain after fitting LED's
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Following the good advice given by this forum, I fitted LED’s to all the “normal” places (front sidelights, interior roof lights, door puddle lights, dashboard end, footwell etc.), only to find the next morning my battery was flat.
I thought this was a one off, and put it down to having the doors open and the radio on whilst completing the task, I even considered that I may have left the interior lights on. But it happened again a week later, this time the battery was so flat that it had triggered the alarm and I had to use the key itself to gain entry as the remote didn’t work.
I’ve had the charging system checked and it’s all fine, all the LED’s have been removed and the filament lamps restored, so far one week later, no problems.
Any thoughts?
L322 2002 Petrol
Post #128078 28th Jun 2012 9:46am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Very odd - I have all mine switched and not had any battery woes. Once the car is off there's no reason it should be providing power to any lighting system, unless the light is actually switched on, and even then the interior light system shuts down after a certain time even if left on..... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #128083 28th Jun 2012 10:18am
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
yeah the LEDs were draining your battery Rolling Eyes
on a serious note i had the AA (friend) do a 24 hour monitered test on my RR. as every so often i would have a dead battery for no obvious reason
It turns out there is a drain on the battery if goto into the boot when the car has been turned off for a while from the cabin (normal after driving). if you then close the boot and lock car and not going into the cabin the tv/satnav screen does not shutdown (as supposed to after 18mins). this was still on hours after supposed shutdown causing a ampage drain.
we tried various combinations and the one above seems the only drain issue.
just thought i would put this out there.
Post #128086 28th Jun 2012 10:22am
millerj90
Many thanks Polux - I think you may be onto something. Thinking about the day(s) that it happened there was a lot of "tailgate" activity, with only the odd occasion to enter the cabin.
Perhaps it's best to enter the cabin after every visit to the tailgate to ensure that the SatNav shuts down.
Many Thanks
Post #128093 28th Jun 2012 10:32am
just replace the bulbs in batches until you find the culprit ,if there is one of course... ... - .- -.
Post #128106 28th Jun 2012 11:25am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Strange if they are off they are off. If they are Led or filament lamps it makes no difference
but the FF is a fickle beast where batterys are concerned Whistle Mine was a blue one! Smile
Post #128118 28th Jun 2012 11:52am
