![]() | Home > Maintenance & Mods (L322) > Poll. What pressure cap is fitted to your M62 V8 |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
There is a lot of confusion about what is correct.
Once you have had black you will never go back! 200 on mine. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 ![]() ![]() ![]() |
200 on mine too - August 04 BMW petrol 4.4
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
Mine has the yellow insert.
The design could be to reduce emissions and not because it is "better" for the engine. Not saying that it is like that here but could be. Same with the fuel system programming, they are based on improving the emissions (based on the standard tests) and that is not always optimum driveability. MY 2010 5.0 SC Galway green and sand interior!!
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
140 on mine. 2003 . Gulp should I be worried? 2003 Vogue 4.4 V8 Java Black |
Do you have any problems at 140? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
It's on it's second engine! Due to overheating |
