![]() | Home > Wheels & Tyres > Tyre Pressure |
m90got Member Since: 18 Oct 2011 Location: scunthorpe Posts: 120 ![]() ![]() ![]() |
Please forgive my ignorance but im not sure what pressures i should be running in my BF Goodrich All Terrains 265/65/18 im going on a motor way run towing a 18ft Tin Tent, i have looked at the max pressure on the tyres and it says 80psi but having very little experiance of this size of tyre putting that amount in just doesnt seem right
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
pressures should be in the manual or little sticker on door pillar... ... - .- -.
I did look there first but it only goes up to 255 and im on 265. Current Stable:
mine were on the same 265 profile, use the 255 pressures.. ... - .- -.
Cheers Stan Current Stable:
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
It is not a recommended tyre size and appears over diameter by @ 2.5% - 5%. (rolling diameter is 122mm more than standard tyre size)
it was a standard OE size on my range tim.. |
So is it on your label stan?
not on label but defo OE size....that 19 is a spacesaver..
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Run my 265/50/20's at 36/44 when towing no problems |
AJS4X4 Member Since: 08 Jun 2012 Location: Surrey Posts: 276 ![]() |
It's a nats wisker larger but I would up 2psi myself, always best to over inflate than under. |
