Home > Wheels & Tyres > Tyre Pressure
m90got
United Kingdom 2003 Range Rover HSE Td6 Alveston Red
Tyre Pressure
Please forgive my ignorance but im not sure what pressures i should be running in my BF Goodrich All Terrains 265/65/18 im going on a motor way run towing a 18ft Tin Tent, i have looked at the max pressure on the tyres and it says 80psi but having very little experiance of this size of tyre putting that amount in just doesnt seem right
so i thought i would ask the people with the most experiance
Cheer Paul. Current Stable:
Range Rover 2003 TD6 HSE Alveston Red, Sand Leather
Ford Focus C-Max silver 2003
V/W transporter Blue 1995
Yamaha XJR1300 Yellow 2002
Kawasaki ZX7R Green 1998
Honda CBR 600 Black 1998
Yamaha RD125LC Mk1 Red 1986
Yamaha RD125LC Mk1 Blue 1986
Post #127697 26th Jun 2012 11:51am
pressures should be in the manual or little sticker on door pillar... ... - .- -.
Post #127698 26th Jun 2012 11:55am
m90got
I did look there first but it only goes up to 255 and im on 265. Current Stable:
Post #127704 26th Jun 2012 12:22pm
mine were on the same 265 profile, use the 255 pressures.. ... - .- -.
Post #127708 26th Jun 2012 12:39pm
m90got
Cheers Stan Current Stable:
Post #127709 26th Jun 2012 12:39pm
It is not a recommended tyre size and appears over diameter by @ 2.5% - 5%. (rolling diameter is 122mm more than standard tyre size)
I would suggest (man on internet forum gives advice that need not be followed and carries no liability!) you follow the pressures on the door label.
A garage would probably pump them to 36 front 44 rear for your load. But take it easy, as the oversized tyres may put an undue strain on your transmission. .
Post #127711 26th Jun 2012 12:44pm
it was a standard OE size on my range tim.. Thumbs Up ... - .- -.
Post #127713 26th Jun 2012 12:48pm
So is it on your label stan?
I have a weird one on mine T175/80/19 what does that tyre look like ? .
Post #127724 26th Jun 2012 1:08pm
not on label but defo OE size....that 19 is a spacesaver..
edit.. just double checked an old invoice and mine were 265/60/18 as opposed to OP's 65 series, but the pressures are the same as the 255's.... ... - .- -.
Post #127727 26th Jun 2012 1:17pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Run my 265/50/20's at 36/44 when towing no problems Thumbs Up Mine was a blue one! Smile
Post #127742 26th Jun 2012 2:30pm
AJS4X4
It's a nats wisker larger but I would up 2psi myself, always best to over inflate than under. Thumbs Up
Post #129192 3rd Jul 2012 12:54pm
