Home > Off Topic > iPhone Jailbroken
iPhone Jailbroken
Right ive taken the leap and jailbroken my iphone. Now what? I did it as i know there are loads of things that can be done once jailbroken, but what and how? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127338 23rd Jun 2012 9:14pm
DMRR
First question - why Jailbreak if you don't know what you want to do Wink
Second - do you have any banking apps on your iPhone - if so, you now find they won't work. Best plan - jailbreak your spare iPhone and play on that Very Happy Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #127339 23rd Jun 2012 9:18pm
I like the idea if getting round apples locks. Would like flash player so I can watch sports etc in work and also change my ip so I can get on the wifi. I just checked my natwest app and it worked???? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127341 23rd Jun 2012 9:27pm
DMRR
Natwest ... did you get paid yet? <snigger>
If you wanted hacked paid apps - there's an app for that.
If you want to make the phone more useful - there's a lot of apps, it just depends on what u want to do ..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #127342 23rd Jun 2012 9:31pm
Nope not paid yet! Censored How do I get free apps and how do I get music back on it? I still have an iTunes and app store icon? Why does my natwest app work when you say it shouldn't? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127354 23rd Jun 2012 9:40pm
DMRR
Secure banking apps will refuse to run on Jailbroken phones (Barclays for one) for good reason. Once you jailbreak it... if it was in my house I could SSH onto it and bingo Wink
Bit worrying that the Natwest one isn't aware....however.
Music etc, use iTurd (I mean iTunes) - the Jailbreak if you used a good break like RedSnow should not have wiped your music at all.....
Free apps - google for the repository for installous .......get the version for your version of IOS. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #127357 23rd Jun 2012 9:49pm
I used absinthe to jailbrake and it was dead easy. I have no music as removed it before I jailbroke as wasn't sure what would happen. If I plug it into iTunes it will try and unjailbrake? What is a repository and installious? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127361 24th Jun 2012 6:14am
daveo
you can use itunes, it will not reverse it unless you update, have you installed instalious and cydia... V8 facelift Range Rover Autobiography 22" wheels.
Post #127372 24th Jun 2012 8:40am
Yer just installed installious. Currently installing tomtom. I was trying to get another app but kept coming up API error? So I can still sync music etc but not update firmware? Do I need to add more repositionary things? Work keep blocking IP address's from the wifi. Is there an app to change my IP when I need to? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127378 24th Jun 2012 9:05am
this site regularly comes up with good cydia apps.. http://www.redmondpie.com/ ... - .- -.
Post #127385 24th Jun 2012 9:24am
DMRR
Er...you don't need to Jailbreak to do that, just go to settings and change the settings to static IP ... then change your IP.....
If you mean they are blocking external addresses - then browse via a proxy, you can't 'change' the IP of somewhere out on the internet. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #127391 24th Jun 2012 9:49am
trafpol
United Kingdom 2006 Range Rover Autobiography Td6 Buckingham Blue
The simple rules are
Always back up the phone - I keep seperate iTunes library for jailbroken devices
Never update to latest firmware until you know it can be jailbroken.
Update Cydia on regular basis as without this the base functions used will stop working
I either get my apps from Installous or direct from here- http://apptrackr.cd/ - you can download staright to computer and manage everything from there, drag and drop to itunes etc. Much faster than downloading to phone.
When you get a bit more advanced with its the use you can use Open SSH methods to view everything and manage the phone without using iTunes.
Best advice is if you have a jailbroken App that works fine, don't upgrade to a newer version if you don't need to (Installous will indicate updates available just as Appstore does). For example SkyGo latest update has now removed the jailbroken device functionality. Big Cry 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #127433 24th Jun 2012 3:03pm
