![]() | Home > Dealership & Service Feedback > I was considering buying a 2011 Vogue - LRCS cured me! |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Muddy have you tried a slightly earlier one? still a cracking car without the bigger engine or save loads and get a supercharged if you are not doing high milage LPG always an option and if you work out what you will save on the vehicle against fuel. ( and remember the new model will probably hammer value of a nearly new)
m3mjw Member Since: 10 Feb 2012 Location: Sunderland Posts: 118 ![]() ![]() ![]() |
Like Gaz said I am afraid. It took me ages to get my head around the loss I was going to take on m5. Higher risk less money so they leave plenty in it. Pal of mine trades high end cars he also singing from same hymn sheet. Sorry mate same old you buy high and sell low! Good luck L405 4.4 SDV8 Santorini/Black VSE
Muddywheels Member Since: 18 Jun 2012 Location: East Riding of Yorkshire Posts: 394 ![]() ![]() |
Gazellio - thanks for the info - I have factory privacy, before the service last month it was pristine, LR Warranty to Nov 2014, and detachable towbar with 13 pin electrics so expected more |
My RRS still not sorted and found out my dealer has been bought by Hatfield |
Awkward but not your problem whoever own's the dealership.
Sure have |
Mutley Member Since: 29 Jun 2011 Location: Reading, Berkshire Posts: 172 ![]() ![]() ![]() |
Hi Muddy, not sure if you have mentioned this before but how big/how much was the repair if its really big I would get a lawyer involved that may make the dealer sort you out more favourably don't sit on promises most corporate companies really don't give a monkeys if that make sure they put everything right, all they want is you out of there faces.
Not sure what the repair bill is as they have not told me but looks as though I may not have to get it back |
Ukdave104 Member Since: 26 Apr 2012 Location: Aberdeen Posts: 116 ![]() ![]() ![]() |
That's a good price for the vogue, how many miles on it |
23000 miles but I only do 7k a year so not a problem |
I don't believe it |
Did you pull that fuse I posted last night |
No - I read what you sent but chickened out because its not mine and did not want any comeback from dealer |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Pulling a fuse cannot do any harm and my guess is the technical bulletin refers to the 2010MY onwards. Take the fuse out, then put it back in and if all is well ring the dealer to say its sorted and hang on to the proper Range Rover |
