![]() | Home > In Car Electronics (L322) > factory speakers |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Dave, see if you can find someo e breaking an 06>MY logic 7 car and buy all the speakers from that... Wow! What an improvement even with the standard amp in the early car... Done it several times... With great results...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
I asked a similar question here ;
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 ![]() ![]() ![]() |
Mine (05 Vogue) came already fitted with the Logic 7 Harmon Kardon system & it sounds awesome, so I'd heartily recommend updating your system.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
ok, now my car is fitted with the logic 7 . 12 speaker system but they don't say harmen karden on the grills, so are the harmen standard on the 06 and up ..
I believe so........ part of the 2005MY facelift.
so would the logic 7 system come with harmon kardon speakers or standard LR ones just more of them, i will have to whip one out and have a look at the back, if it is a HK will that be the best i can get or are the 2006 HK ones better, V8 facelift Range Rover Autobiography 22" wheels.
Mine is a VSE if that makes any difference? And says HK Logi 7 on the speaker grills... I take it you have touch screen?
hi Craig, no my grills only have the logic7 badge on them but no silver ring round them and no mention of harmon kardon are on the grill but it has the 12 speakers, now does the logic mean that it has the 12 speaker system but could still have the standard LR speakers, one other thing has any one got the logic 7 system and DSP as i don't have the DSP, was told by the dealer you wont have both, i could kick my self as i had the door panel of the other day V8 facelift Range Rover Autobiography 22" wheels.
Dave, I've just been out to look for you and it says Harmon Kardon Logic 7 on all four door speakers with a silver ring round them...
now my ones just have logic 7,no silver ring. i think i will have to ave the trim off to see if they are HK or not, craig do you know if the early HK speakers are the same as they fitted to the later cars as like the ones you got, or did they improve them. V8 facelift Range Rover Autobiography 22" wheels.
No idea I'm affraid Dave... Worth checking though, I have a late set so when I get back from my hols I will post a part number or pic or something for reference pal...
thanks mate |
Just looking online to try and find out a bit more.
Turbo Tony Member Since: 06 Apr 2010 Location: London Posts: 243 ![]() ![]() |
Dave, while the door cards are off, measure the diameter of the speaker and see if it has an impedance rating.
