Home > In Car Electronics (L322) > factory speakers
daveo
factory speakers
has any one sourced direct after market replacement speakers for the RR doors. V8 facelift Range Rover Autobiography 22" wheels.
Post #124999 5th Jun 2012 12:08pm
Dave, see if you can find someo e breaking an 06>MY logic 7 car and buy all the speakers from that... Wow! What an improvement even with the standard amp in the early car... Done it several times... With great results...
Craig Thumbs Up
Post #125004 5th Jun 2012 12:36pm
mjdronfield
I asked a similar question here ;
http://www.fullfatrr.com/forum/topic10416.html?highlight=speaker
but didn't get any replies, as I was talking putting the newer speakers being fitted in the older car.......
So it can be done then.
I've already upgraded the BM54 amp, so the newer speakers would be ideal........
Does anyone have part number ?
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #125005 5th Jun 2012 12:44pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
Mine (05 Vogue) came already fitted with the Logic 7 Harmon Kardon system & it sounds awesome, so I'd heartily recommend updating your system.
Regards..Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #125019 5th Jun 2012 2:43pm
daveo
ok, now my car is fitted with the logic 7 . 12 speaker system but they don't say harmen karden on the grills, so are the harmen standard on the 06 and up ..
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #125040 5th Jun 2012 4:51pm
mjdronfield
I believe so........ part of the 2005MY facelift.
Didn't think a 2006 onwards car was different.
My early car has an HK system, according to the brochure, but again, no speaker badge. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #125075 5th Jun 2012 8:42pm
daveo
so would the logic 7 system come with harmon kardon speakers or standard LR ones just more of them, i will have to whip one out and have a look at the back, if it is a HK will that be the best i can get or are the 2006 HK ones better, V8 facelift Range Rover Autobiography 22" wheels.
Post #125084 5th Jun 2012 9:55pm
Mine is a VSE if that makes any difference? And says HK Logi 7 on the speaker grills... I take it you have touch screen?
Craig Thumbs Up
Post #125085 5th Jun 2012 10:22pm
daveo
hi Craig, no my grills only have the logic7 badge on them but no silver ring round them and no mention of harmon kardon are on the grill but it has the 12 speakers, now does the logic mean that it has the 12 speaker system but could still have the standard LR speakers, one other thing has any one got the logic 7 system and DSP as i don't have the DSP, was told by the dealer you wont have both, i could kick my self as i had the door panel of the other day V8 facelift Range Rover Autobiography 22" wheels.
Post #125089 5th Jun 2012 11:00pm
Dave, I've just been out to look for you and it says Harmon Kardon Logic 7 on all four door speakers with a silver ring round them...
Craig Thumbs Up
Post #125092 5th Jun 2012 11:08pm
daveo
now my ones just have logic 7,no silver ring. i think i will have to ave the trim off to see if they are HK or not, craig do you know if the early HK speakers are the same as they fitted to the later cars as like the ones you got, or did they improve them. V8 facelift Range Rover Autobiography 22" wheels.
Post #125095 6th Jun 2012 12:10am
No idea I'm affraid Dave... Worth checking though, I have a late set so when I get back from my hols I will post a part number or pic or something for reference pal...
Craig Thumbs Up
Post #125099 6th Jun 2012 6:47am
daveo
thanks mate Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #125113 6th Jun 2012 9:02am
mjdronfield
Just looking online to try and find out a bit more.
Found this, but this may be what daveo has fitted already ?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #125135 6th Jun 2012 12:31pm
Turbo Tony
Dave, while the door cards are off, measure the diameter of the speaker and see if it has an impedance rating.
THere are loads of aftermarket manufacturers that sell custom fit speakers, designed to replace standard equipment in the standard locations.
Most often, though, they are a standard sizes and 4ohn impedance... It's only when you get to certain branded audio systems (like Bose) who use irregular impedance like 3 ohm to squeeze a little more power out of the amp and make upgrading a little more difficult. Researching my first Range Rover purchase
Post #125190 6th Jun 2012 6:18pm
