![]() | Home > LPG > lpg help |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
Look on components under the bonnet... My £1 goes on a Prinns system looking at that switch...
As Craig said, take the acoustic cover off the engine bay and look at the injectors and vaporiser. Also there should be an ECU knocking round somewhere. Mines in the waterproof box holding all the ECU's. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1443 ![]() ![]() |
A lot of the switches and sensors are common components between systems. That switch looks like mine which is a Romano system, but I've seen one on other makes too. As already said, look at the injectors or the reducer unit to find the make. V8 or else ... |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1045 ![]() ![]() |
As Fisha said, the gauge tells you nothing, I had it on a system, cant remember make but not Prins or Romano. You need to check that the vehicle is approved, so if you have no certificate or paperwork, take it to an LPG specialist for certification, get it serviced at the same time if you have no paperwork got it.
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
ive just had a look and its a zavoli setup
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
I've got a Zavoli kit on one of our cars and it's been faultless to be honest.
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
I have run the Zavoli system on both our 4.4s one has covered 80k and the other 50k and they have both been faultless.
