Home > LPG > lpg help
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
lpg help
ive got an lpg system fitted on my FF and dont know what lpg system it is where should i be looking to see what model it is
this is what the lpg gauge looks like if that helps
Post #124894 4th Jun 2012 12:26am
Look on components under the bonnet... My �1 goes on a Prinns system looking at that switch...
Craig Thumbs Up
Post #124902 4th Jun 2012 8:17am
As Craig said, take the acoustic cover off the engine bay and look at the injectors and vaporiser. Also there should be an ECU knocking round somewhere. Mines in the waterproof box holding all the ECU's. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #124907 4th Jun 2012 9:06am
fisha
A lot of the switches and sensors are common components between systems. That switch looks like mine which is a Romano system, but I've seen one on other makes too. As already said, look at the injectors or the reducer unit to find the make. V8 or else ...
Post #124918 4th Jun 2012 10:08am
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
As Fisha said, the gauge tells you nothing, I had it on a system, cant remember make but not Prins or Romano. You need to check that the vehicle is approved, so if you have no certificate or paperwork, take it to an LPG specialist for certification, get it serviced at the same time if you have no paperwork got it.
Certification and a service will set you back around �100. Without getting it certified, your insurance may not be valid. Big Cry 2012 SDV8 Vogue SE
Post #124921 4th Jun 2012 10:50am
dannyp15
ive just had a look and its a zavoli setup
1 are they any good
2 anyone now how to update the software
Post #124959 4th Jun 2012 7:11pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I've got a Zavoli kit on one of our cars and it's been faultless to be honest.
To re-tune all you need is a laptop, a lead and some software. It's probably best to take take it to a Zavoli installer for a full lpg service though.
Jonno 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #124985 5th Jun 2012 5:38am
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
I have run the Zavoli system on both our 4.4s one has covered 80k and the other 50k and they have both been faultless.
I have just changed to a 4.2 SC Autobiography and again fitted a Zavoli system and now its set up ok is running fine.
Stewart.
Post #125001 5th Jun 2012 12:17pm
