Home > Technical (L322) > car wont turn over! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
sounds like the battery..you may have lights etc but not battery power to turn it over... |
3rd Sep 2011 11:09am |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Yep, I would start at the battery.
3rd Sep 2011 11:40am |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
mine did this yesturday id put all my money on your battery "RANGEISM WILL NOT BE TOLERATED"
3rd Sep 2011 12:51pm |
killatomato Member Since: 14 Jul 2011 Location: Wirral Posts: 41 |
Hi guys it's happened again, so I called RAC. Guess what happens as soon as he arrives the thing fires up. Then we tried about 20 times and only 2/3 times it did not turn over. So it should not be the battery but a faulty part - lock barrel? Solenoid? |
20th Sep 2011 12:56pm |
Hello, anybody have any ideas? I really don't want to go to the stealers! |
21st Sep 2011 10:42am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Gearbox inhibitor switch?
21st Sep 2011 11:02am |
still reckon its the battery....how old is yours ,if over about 3 years then its time to change.. ... - .- -.
21st Sep 2011 1:06pm |
The battery is less than a year old. Its been starting fine for the last day, even though I was doing stop/start journeys. |
21st Sep 2011 9:55pm |
ok then, in the words of homer, 'i dont know'. ... - .- -.
22nd Sep 2011 7:31am |
Poor earth to the starter, knackered starter, broken wire, inhibitor switch on gearbox, blown fuse, there are so many things that could cause this problem and only by working through some of the more common faults will you be able to eventually find the cause |
22nd Sep 2011 7:46am |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
My money would be on a battery too, mine used to do it if the car had been standing for a week or so. 2006 Mercedes CLS
22nd Sep 2011 5:04pm |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
Mine does this occasionally, even though she starts fine after removing and re-inserting the key. |
22nd Sep 2011 6:01pm |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 |
i had this problem too, it turned out to be a faulty module in the steering column 2002 td6 vogue, 06 supercharged facelift
22nd Sep 2011 7:53pm |
Darrenmax, do you know what the module was?. |
23rd Sep 2011 8:32pm |
