Home > Technical (L322) > car wont turn over!
killatomato
United Kingdom 2005 Range Rover Vogue Td6 Java Black
car wont turn over!
Hi, my car now has a new problem! When I get in to start the car it does not even crank the engine. I can hear the fuel pumps doing their bits and the battery seems strong enough no fading light or fault codes. When I turn the key all I can hear is there is light whirring noise from under the gear lever. Is there a motor there that connect to the starter? Or is my key not recognised by the immobiliser? I starting to regret buying the thing as all I have been doing the last month that I've had it is visiting garages! And I got rust on the rear arches which I did not notice when checking over the car. I woul have presumed for such a prestigr car that would not be problem. It is a 2005/55 facelift Td6 vogue 60k, remapped. Big Cry
Post #78969 3rd Sep 2011 11:01am
sounds like the battery..you may have lights etc but not battery power to turn it over...
Post #78971 3rd Sep 2011 11:09am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Yep, I would start at the battery.
Get a volt reading off the battery and see what state it's in.
Good luck.
Post #78974 3rd Sep 2011 11:40am
pretlove
mine did this yesturday id put all my money on your battery Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #78981 3rd Sep 2011 12:51pm
killatomato
Hi guys it's happened again, so I called RAC. Guess what happens as soon as he arrives the thing fires up. Then we tried about 20 times and only 2/3 times it did not turn over. So it should not be the battery but a faulty part - lock barrel? Solenoid? Banging Head
Post #82603 20th Sep 2011 12:56pm
killatomato
Hello, anybody have any ideas? I really don't want to go to the stealers!
Post #82810 21st Sep 2011 10:42am
Gearbox inhibitor switch?
Starter relay?
Post #82812 21st Sep 2011 11:02am
still reckon its the battery....how old is yours ,if over about 3 years then its time to change.. ... - .- -.
Post #82830 21st Sep 2011 1:06pm
killatomato
The battery is less than a year old. Its been starting fine for the last day, even though I was doing stop/start journeys.
Post #83039 21st Sep 2011 9:55pm
ok then, in the words of homer, 'i dont know'. ... - .- -.
Post #83057 22nd Sep 2011 7:31am
Poor earth to the starter, knackered starter, broken wire, inhibitor switch on gearbox, blown fuse, there are so many things that could cause this problem and only by working through some of the more common faults will you be able to eventually find the cause
Post #83062 22nd Sep 2011 7:46am
M44K TS
My money would be on a battery too, mine used to do it if the car had been standing for a week or so. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #83257 22nd Sep 2011 5:04pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Mine does this occasionally, even though she starts fine after removing and re-inserting the key.
Post #83284 22nd Sep 2011 6:01pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
i had this problem too, it turned out to be a faulty module in the steering column 2002 td6 vogue, 06 supercharged facelift
Post #83333 22nd Sep 2011 7:53pm
DavidP
Darrenmax, do you know what the module was?.
Post #83562 23rd Sep 2011 8:32pm
