Home > Maintenance & Mods (L322) > ZF Oil Change / Service Quote - Mackie Transmission |
They're having a laugh....at your expense, you could drive a bus between the box and the bodywork |
18th May 2012 7:44pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
My thoughts exactly......
18th May 2012 7:47pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3163 |
Danuk1984 had his oil amd filter changed at his usual indie guy for around £180 I recollect? |
19th May 2012 2:47pm |
I bought this kit and then it still needed work done. Please note that it has only 7 liter of fluid so the gearbox is not completely drained (I believe it takes about 14 liter). So that is already GBP 160 for all this stuff and then there is still the work. I have to say the filler plug is hard to get to but the filter etc. is dead easy. Although over here they said that some of the bolts were stuck (galvanic corrosion ??) taking some extra time to remove.
19th May 2012 6:37pm |
Collie35 Member Since: 02 Aug 2012 Location: East Links (Edinburgh) Posts: 2 |
I also took my RR to Mackie Transmission for a transmission service, can't remember exactly how much it cost (several months ago), But as i remember thinking it was quite good value, they also downloaded the lastest software into the computer and car drove like a dream (still does) on the way back. I drove through from Edinburgh especially. |
2nd Aug 2012 1:29pm |
2nd Aug 2012 1:32pm |
Good to hear a recommendation.....thanks Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
2nd Aug 2012 5:57pm |
