Home > Wheels & Tyres > TPMS valve stem snapped
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
So I had the unfortunate experience of a TMPS valve stem snapping today which gave me a chance to learn how much fun it is to change a FFRR tyre on your own while wearing a suit! Do I have to get a new TPMS unit from the stealer or can it just have a new stem done at a tyre place? It's only sheared off about 8mm, but obviously this bit holds the valve so I lost all the air, but I am hoping this means the TPMS unit is safe?
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #122244 16th May 2012 10:25pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
No - all one piece (been there - done that)...
...they are available off the fleabay (cheaper than LR dealer)
Edit ... Would recommend you get all 4 valves replaced Whistle
Post #122246 16th May 2012 10:31pm
TheAllSeeingPie
Cheers delamo! Do they need a stealer to re-code them to the car? Or is it a fit and drive for a bit thing?
Post #122247 16th May 2012 10:42pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Out of interest, were you checking the pressure at the time ?
Mine dont look to healthy, I was checking pressures last week and was a bit nervous ! Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #122269 17th May 2012 6:50am
TheAllSeeingPie
It happened after putting air in. As I pulled the hose away the valve was in the air hose and flew off somewhere.
Post #122271 17th May 2012 6:55am
metal valves are always going to be prone to corrosion, best stick rubber ones in even if it means loosing the tpms .. ... - .- -.
Post #122298 17th May 2012 8:47am
sleepezy
delamo wrote:
...they are available off the fleabay (cheaper than LR dealer):
...just worth a check though, I have seen them more expensive on fleabay
Post #122302 17th May 2012 8:50am
TheAllSeeingPie
So it appears they are £61 a corner fitted from a main stealer. Unfortunately this time I am going to have to accept as my spare appears to be lacking any balancing weights and made my 45 mile commute to work a bit wobbly.
Post #122322 17th May 2012 9:19am
delamo
Sounds like you got a deal from the LR dealer ... when I broke mine the dealer quoted more than that per corner just for the part (not fitted)... I know the ones I found on the eBay (genuine LR/Jaguar part) were approx 3/4 the price of what dealer quoted and delivered well within 24hours, but - I have noticed (since my problem) that others on here have managed to source them much cheaper still.
Once fitted (by local tyre fitter) they synced themselves to the car (no need to be programmed) by the time I got back home.
Mine broke because I thought one day it were a great idea to fit shiny metal valve dust caps - turns out - these little f**kers welded themselves to the tpms valve stem within weeks ... went to check pressures one day and couldn't remove caps using fingers - thought I'd gently used some pliers and PSSSSSSSSSSSSSSSSSSTT! Censored ... x4
Stan does make a very good point 'bout using standard rubber/brass valves (if you can live with the warning light being on) because even brand new tpms valves appear they are manufactured from a very light (weak) alloy of one kind or another and don't look like they would cope too well with elements or road salt etc. and very likely could start to corrode almost immediatly?
Good luck sorting yours out T A S P
Post #122378 17th May 2012 2:17pm
TheAllSeeingPie
All sorted now. Took them a bit longer than quoted to fit, but they stuck to their price. Think it was £61.26 and I even got a couple of free coffees (so saved a fiver there!). Also knowing that I can get good service from a dealer I drive past on the way to and from work is a nice feeling too.
Post #122380 17th May 2012 2:35pm
@delamo, i was led to believe that if there are no tpms valves fitted then the fullfat wont pick up a signal and hence no warning lights.. ... - .- -.
Post #122384 17th May 2012 2:46pm
Stan, if you fit non TPMS valved wheels, the control unit throws up errors. I know this because I've just swapped my (TPMS) valved wheels for non TPMS ones and the tyre warning light flashes for a while, then stays on permanently. It;s also accompanied by the "check all tyre pressures" message.
Roll on the IIDTool s/w update! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #122385 17th May 2012 2:50pm
thanks for the info alan.... Thumbs Up ... - .- -.
Post #122387 17th May 2012 2:51pm
delamo
^^^ You could be right Stan - I just assumed the light would show (thought I read on here somewhere - that someone had a spare set of off-road wheels/tyres without the tpms - and when fitted the light came on and stayed on until original wheels were replaced)
Glad you got them sorted T A S P - couldn't agree more with the local dealer satisfaction feeling ... bet you can't wait for the next think to go wrong now? Wink
Post #122389 17th May 2012 2:54pm
TheAllSeeingPie
Actually I was eyeing up a Mini in the next door garage as they had quite nice staff there. I reckon I would be in there every week with something broken Thumbs Up
Post #122395 17th May 2012 3:10pm
