![]() | Home > Wheels & Tyres > TPMS valve stem snapped |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
So I had the unfortunate experience of a TMPS valve stem snapping today which gave me a chance to learn how much fun it is to change a FFRR tyre on your own while wearing a suit! Do I have to get a new TPMS unit from the stealer or can it just have a new stem done at a tyre place? It's only sheared off about 8mm, but obviously this bit holds the valve so I lost all the air, but I am hoping this means the TPMS unit is safe?
Cheers delamo! Do they need a stealer to re-code them to the car? Or is it a fit and drive for a bit thing?
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Out of interest, were you checking the pressure at the time ?
It happened after putting air in. As I pulled the hose away the valve was in the air hose and flew off somewhere.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
metal valves are always going to be prone to corrosion, best stick rubber ones in even if it means loosing the tpms .. ... - .- -.
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
...just worth a check though, I have seen them more expensive on fleabay |
So it appears they are �61 a corner fitted from a main stealer. Unfortunately this time I am going to have to accept as my spare appears to be lacking any balancing weights and made my 45 mile commute to work a bit wobbly.
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
Sounds like you got a deal from the LR dealer ... when I broke mine the dealer quoted more than that per corner just for the part (not fitted)... I know the ones I found on the eBay (genuine LR/Jaguar part) were approx 3/4 the price of what dealer quoted and delivered well within 24hours, but - I have noticed (since my problem) that others on here have managed to source them much cheaper still.
All sorted now. Took them a bit longer than quoted to fit, but they stuck to their price. Think it was �61.26 and I even got a couple of free coffees (so saved a fiver there!). Also knowing that I can get good service from a dealer I drive past on the way to and from work is a nice feeling too.
@delamo, i was led to believe that if there are no tpms valves fitted then the fullfat wont pick up a signal and hence no warning lights.. ... - .- -.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6760 ![]() ![]() ![]() |
Stan, if you fit non TPMS valved wheels, the control unit throws up errors. I know this because I've just swapped my (TPMS) valved wheels for non TPMS ones and the tyre warning light flashes for a while, then stays on permanently. It;s also accompanied by the "check all tyre pressures" message.
thanks for the info alan.... |
^^^ You could be right Stan - I just assumed the light would show (thought I read on here somewhere - that someone had a spare set of off-road wheels/tyres without the tpms - and when fitted the light came on and stayed on until original wheels were replaced)
Actually I was eyeing up a Mini in the next door garage as they had quite nice staff there. I reckon I would be in there every week with something broken |
