Home > General > Anybody know the size of the rear wiper on an 07 Range?
5IMON
I think its 16/17 inches but im not sure
Post #119941 2nd May 2012 12:10pm
Mutley
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Hi Simon, I can't help but you beat me to it as I need a new wiper for the rear of my MY08 so any help also apprectiated, they are probably the same. Whistle
Sorry for the hijack Mutt
FFRR Black TDV8 Vogue MY08
Post #119942 2nd May 2012 12:13pm
My rear wiper blade is 18" ….. Thumbs Up
Post #119943 2nd May 2012 12:17pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Not only the size, but a cheap source http://www.fullfatrr.com/forum/topic10146.html (and I'm still happy with the purchase)
Post #119945 2nd May 2012 12:49pm
5IMON
Post #119957 2nd May 2012 2:17pm
measure it? Shocked Discovery 4 HSE
Post #119961 2nd May 2012 3:00pm
...or, i put ''range rover rear wiper'' into google and came up with the part number and loads of prices.....
i gather there must be a reason why OP wanted the size... ... - .- -.
Post #119963 2nd May 2012 3:33pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
As per Vaguely Vogue above:
18" Bosch £5.28 delivered. Ordered Wednesday, arrived Thursday morning in a heavy duty tube. GSF Car Parts on eBay search for "Bosch 18 Inch Wiper Blade RENAULT SUPER 5 84-96".
I just ordered on Tuesday. Arrived and fitted today. Brilliant.
Cheers Very Happy 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #119966 2nd May 2012 3:52pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i can't remember, but can you change the rear blade without taking the spoiler off?? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #119977 2nd May 2012 5:14pm
mjdronfield
Turn the ignition off when the rear wiper is pointing downwards, and you can get to it.
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #119979 2nd May 2012 5:16pm
stu
nice one...i knew it was something like that.... Whistle Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #119981 2nd May 2012 5:20pm
As per Vaguely Vogue ebay link
Arrived within 24 hours, fitted in seconds Smile
The packaging doesn't give too much away:
Bosch Superplus 18 (450mm)
3 397 008 362 -4ZA
Fitting:
Ignition on
Rear Wiper on
Quickly turn ignition off when wiper blade in middle of rear screen
Lift wiper arm (it's stiff but will come up about 1ft from the rear screen)
Press in the little tab/s on the sliding connector and remove old wiper
Slot the new wiper into place
Push wiper and wiper arm down onto the rear screen to get a good contact
Ignition on, rear wiper off. ignition off
Job done
Post #120427 5th May 2012 2:33pm
Rambles
if you have a MY11, it is ignition on, turn wiper on, when wiper vertical open tailgate, turn ignition off, change wiper blade.
if you just turn off the ignition the wiper will still complete the wipe.
but thanks for the heads up on Bosch wipers forum members. I have them front and back now and i can see in the rain without much of the thudding and smearing.
Post #121039 9th May 2012 5:44pm
